Fine connector work!
madmax
I just redid the connectors on my phono cable. What a hassle. There were two very fine conductors which had to go to the center post and grounding ring of each RCA connector. Then the cable shield also had to connect to the grounding ring. I'm not much for this very fine work... :mad: I guess I'll find out tonight when I hook it up how many more tries I'll have to make at it.
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
I'm not one for fine connection work yet either, otherwise I would have rewired my TT also.
Hope it works out for you on the first try."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Nice work, Ill be interested to see if it makes a difference.
I've been living with an intermittant ground for years because I hate messing with this fine stuff. It would be fine for a few weeks then all of a sudden start cutting off or making noises. Move it around several times and I was good for another month. Hopefully this fixes it. And it still works...
I went through this when I rewired the RB-250 on my old Rega. I nice adjustable heat iron with a small tip makes it easier.
Good Luck on yours. -
I have the tools here at work, just not fun for me. It worked! I must say I feel the work turned out well. I thought about taking pics but had forgotten my camera.
What kind of cables did you go with and how much of a difference did you notice. The OEM Rega cables appear very cheap on my P1.I went through this when I rewired the RB-250 on my old Rega. I nice adjustable heat iron with a small tip makes it easier.
Good Luck on yours."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Rumor is HI is real good at this stuff, after he is done working on his beloved TT, it goes to the factory where they fix it real good!!!!!!!!!!!
Sorry Joe, could'nt resist............
Glad you are running Max.
RT1 -
There is a real talent in working on this stuff (most patience) especially when you have to fab parts from what you can find from conventional sources. It is often more of a mechanical problem to install parts, cables, jacks, etc, than an electrical one.[
They are DIY made from RG-316 shielded coax. I first had to remove the cheap original cables from the molded end that fits the bottom of the arm. Then fit the new cables through the old holes and solder to the PCB. Last was to resolder the tone arm wires to the opposite side of the PCB. The lesson learned here is patience.
