Fine connector work!
madmax
madmax Posts: 12,434
edited January 2008 in 2 Channel Audio
I just redid the connectors on my phono cable. What a hassle. There were two very fine conductors which had to go to the center post and grounding ring of each RCA connector. Then the cable shield also had to connect to the grounding ring. I'm not much for this very fine work... :mad: I guess I'll find out tonight when I hook it up how many more tries I'll have to make at it. :D
madmax
Vinyl, the final frontier...
Post edited by madmax on
  • Face
    Face Posts: 14,340
    edited January 2008
    I'm not one for fine connection work yet either, otherwise I would have rewired my TT also.
    Hope it works out for you on the first try.
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Nice work, Ill be interested to see if it makes a difference.
  • madmax
    edited January 2008
    I've been living with an intermittant ground for years because I hate messing with this fine stuff. It would be fine for a few weeks then all of a sudden start cutting off or making noises. Move it around several times and I was good for another month. Hopefully this fixes it. And it still works...
    madmax
  • Wardsweb
    Wardsweb Posts: 942
    edited January 2008
    I went through this when I rewired the RB-250 on my old Rega. I nice adjustable heat iron with a small tip makes it easier.
    Good Luck on yours.
  • madmax
    edited January 2008
    I have the tools here at work, just not fun for me. It worked! I must say I feel the work turned out well. I thought about taking pics but had forgotten my camera.
    madmax
  • Face
    Face Posts: 14,340
    edited January 2008
    Wardsweb wrote: »
    Good Luck on yours.
    What kind of cables did you go with and how much of a difference did you notice. The OEM Rega cables appear very cheap on my P1.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2008
    Rumor is HI is real good at this stuff, after he is done working on his beloved TT, it goes to the factory where they fix it real good!!!!!!!!!!!
    Sorry Joe, could'nt resist............
    Glad you are running Max.
    RT1
  • vonnie123
    vonnie123 Posts: 326
    edited January 2008
    There is a real talent in working on this stuff (most patience) especially when you have to fab parts from what you can find from conventional sources. It is often more of a mechanical problem to install parts, cables, jacks, etc, than an electrical one.
  • Wardsweb
    Wardsweb Posts: 942
    edited January 2008
    Face wrote: »
    They are DIY made from RG-316 shielded coax. I first had to remove the cheap original cables from the molded end that fits the bottom of the arm. Then fit the new cables through the old holes and solder to the PCB. Last was to resolder the tone arm wires to the opposite side of the PCB. The lesson learned here is patience.
