HK247 and amplifier
DannyD
DannyD Posts: 133
Hello again audio pros!
I'm in the market to purchase an external amplifier to help give my speakers some more juice. They are currently all running off my HK247 that's sending them 50wpc. I WANT MORE!!! Since my AVR has preouts, does it matter what amplifier I hook up to it or do certain amps work better with HK products? I've been checking the net religiously for an amp and I can't believe how expensive they are! I want to make sure I get the right one the first time. Please advise.
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Post edited by DannyD on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    I have used Adcom's with my HK, and they have played very well. I wouldn't run out, and buy new. You can get a used Adcom for $350 or less if you shop long enough. With the RTI 10s I would suggest a GFA-555.
    Ben
    Ben
  • iskandam
    iskandam Posts: 704
    edited January 2008
    I'm planning on adding an amp and use my HK AVR 247 as a pre-pro as well. How does an Adcom-HK-RTi combination sound? I was thinking either the GFA-6000 or GFA-7400.
    I'm also looking at Carver, B&K and Rotel but haven't pulled the trigger yet because I'm still gathering information on how those different combos will sound. I don't like overly bright sound but I find warm tube sound to be too dull for my taste (all HT, loud action movies)
  • mark090852
    mark090852 Posts: 998
    edited January 2008
    I use a B&K with my system and have been very pleased with the results.
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • peffy03
    peffy03 Posts: 50
    edited January 2008
    i have a carver m-200t running a pair of rti10s and it sounds great. Found it on ebay for around 150$
    heres a link to one on ebay with a day left. no affil
    http://cgi.ebay.com/Carver-M200t-Amp-In-Great-Shape-Works-Perfect_W0QQitemZ120211085026QQihZ002QQcategoryZ39783QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    i also own a carver pm-300 which is very similar to the m-200t, just rackmount and volume control added. Both amps are around 125x2 at 8 ohm and have extremly low harmonic distortion.
    -Jeff
    My System:
    Onkyo Sr604
    Carver 125x2
    Polk Rti 10 (biamped)
    Polk Monitor 30
    Polk psw10bk
    Polk Rti6
    polk CSi3
    Monster ripoff wire
  • Sami
    Sami Posts: 4,634
    edited January 2008
    I'd try B&K out of those amp manufactures as they are on the neutral/warm side. Used ST202 perhaps as it can be had used for a very reasonable price. If you're after 5ch amp then B&K AV5000 is an excellent choice.
    I have found most of the Rotels to be on the bright side so I wouldn't recommend them for RTi's. Adcom is pretty neutral sounding to me.
  • brijenjas
    brijenjas Posts: 311
    edited January 2008
    iskandam wrote: »
    I had an HK340/Adcom GFA6000/RTi8 combo and it sounded pretty good, the slightly bright RTi8 mated with the warm HK, balanced out the sound nicely.
