Increasing the soundstage on my LSI 15's
The openings going into the other rooms behind the speakers are not going to help much.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
dragon1952 wrote: »The openings going into the other rooms behind the speakers are not going to help much.
I was thinking the same thing ... -
phipiper10 wrote: »Tubes will solve that problem. ---I'm kidding, kidding people! And if 200 watts wasn't mentioned I'll toss that out now too ..
Really though I'd just experiment with everything offered above.
I have the 200 watts covered, but not the tubes
I'll continue to experiment, and thanks wizzy on the suggestions about the pillows to absorb the sound, i'll try it out.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
