Hard drive question, part II
edbert
edbert Posts: 1,041
edited January 2008 in The Clubhouse
Alright, I have the hard drive working in my computer, except for one thing. I put my system in standby after I am done using it to save power, the only problem is that my old hard drive that I added as a second drive, doesn't come back "online" so to speak when I take the computer out of standby. Anyone know if there are any settings I can change on the hard drive that I added that will wake it up when I bring the computer back from standby? Thanks again!
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
Post edited by edbert on
  • steveinaz
    steveinaz Posts: 19,546
    edited January 2008
    maybe a setting in your bios for the second HDD port?
  • SKsolutions
    SKsolutions Posts: 1,820
    edited January 2008
    Master/Slave device settings in BIOS. IDE primary/secondary. DMA setting in BIOS too.
    I tinker till it works, you may actually want to know what your doing.:D
    -Ignorance is strength -
