Hard drive question, part II
edbert
Alright, I have the hard drive working in my computer, except for one thing. I put my system in standby after I am done using it to save power, the only problem is that my old hard drive that I added as a second drive, doesn't come back "online" so to speak when I take the computer out of standby. Anyone know if there are any settings I can change on the hard drive that I added that will wake it up when I bring the computer back from standby? Thanks again!
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
Pioneer VSX-816
CS1 - center
XBOX
SOPA since 2008
Here's my stuff.
Post edited by edbert on
maybe a setting in your bios for the second HDD port?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Master/Slave device settings in BIOS. IDE primary/secondary. DMA setting in BIOS too.
I tinker till it works, you may actually want to know what your doing.:D-Ignorance is strength -
