Computer audio output questions
NeilGabriel
I stream a lot of music with my computer, especially Napster. I want to upgrade the quality of the output as well as make sure I am getting the best output from CDs that I record (I have a separate hard drive to put them on).
Can anyone give me a link that will explain this process. I found a couple sites and, as an example, this interface. I know there are threads on the forum about this, but I would like to find a good source that expalins it for dumassies.
http://www.sweetwater.com/store/detail/UA1EX
Is this all I would need, or does this also involve changing out sound cards? Will this help with streaming media or is their quality too low to be improved? Thanks a lot.
Post edited by NeilGabriel on
How much do you want to spend?
You can get a better sound card and a separate DAC, which would be best for gaming. Or you can just get a nice DAC with a USB interface if you're just using the PC for a music server and browsing."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
No gaming. The interfaces I saw were going in the $100 range. I'll spend more to get decent sound since I use the computer as my source so often.
Will the DAC upgrade give me better sound on streaming music if that is of limited quality?
Mike -
I am searching around on this topic also. How do you output music through the usb port?
http://209.132.209.149/products/en_us/Transit-main.html
Plug this into a usb port and it gives an optical out. Make sure you install an ASIO driver (you can search for one) I use asioforall. Doing this will give you a true bit out bypassing windows' mixing drivers that mess with the digital output.
You can then pay around with any DAC that has an optical in.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
How does this differ from the one I linked in my first post? I think that has a DAC in it and runs rca /analog outputs. Oh, and it provides for recording in the computer as well. Thanks lots. -
what internal card does your pc have?
why not consider an internal one?ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
I don't know but I can figure that out. It would be standard grade that came with the Dell. But I would need to take it in to a shop for internal work. I switched out RAM cards, but that is the extent of my computer skills.
I know there have been prior posts on this issue, but they get really hard to follow. -
NeilGabriel wrote: »How does this differ from the one I linked in my first post? I think that has a DAC in it and runs rca /analog outputs. Oh, and it provides for recording in the computer as well. Thanks lots.
Whoops, sorry, I never checked the link.
It'll probably do the same. The important part is the ASIO part.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
