What do I set the Crossover point to?
mrpito
Heyya guys,
I'm new here and I'm pretty new to AV systems, but I did my homework and I ended up picking up a pretty descent Yamaha AV receiver, some Polk Audio Monitor series Speakers (Monitor 50 towers, Monitor 30 Rears, CS1 Center) and a Sinclair Audio SW10.3 250 Powered Sub.
Now, i'm trying to figure out what to set my Crossover point at. here's a setting for the Crossover point on the yamaha Receiver so i plan on using that. I have it set at 80Hz right now...
Any help would be appreciated.
cheers!
cheers!
Post edited by mrpito on
agreed ^^^
80Hz is a good place to startCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Dont be afraid to experiment, I run mine @60hz. My 12s and subs seem to blend better @60hz. So try a few different settings.Shoot the jumper.....................BALLIN.............!!!!!
I agree. Sometimes what should be the best solution depends on the listening area so just play around and see what works best for you. But 80Hz would be a good starting point. -
The 50's should be crossed over @ 68.25hz. The 30's should be @ 84.78hz. The cs1 should be @ 78.24hz. Your sub should be @ 89.37 hz. Hope this helps....
Welcome to Club Polk..:DMonitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
