Lets talk CD Players
VR3
Im considering a new CDP...
Brands Im considering are as follows...
Symphonic Line
Wadia
Shanling
Musical Fidelity
I want to stay away from...
Jolida
Yamaha
Rotel
Denon
Marantz
Any of the "big brands"
Just not my style
I'm to arrogant for that
A few that comes to mind
Im thinking new --
2-3k
Any opinions or brands?
I have a friend that may bring over a Wadia CDP for me to try --- my interest is very PEAKED on them... they seem amazing -- ratings through the roof
But of course, I have a soft spot for Symphonic..
This is definitely a 2009 purchase
Symphonic Line
Wadia
Shanling
Musical Fidelity
Jolida
Yamaha
Rotel
Denon
Marantz
Just not my style
Im thinking new --
2-3k
Post edited by VR3 on
I would narrow that to:
Wadia
Musical fidelity
Just my opinion.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
The Tri-Vista is definitely an option I will consider as Ive been very impressed at all the gatherings Ive heard it at...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I have not heard it yet, but good sounds are being reported from the Raysonic that Joe has. That, as I understand fits within your target budget as well.
I thought you were on an audio sabbatical [from buying new gear] this year?
EDIT: Just noticed your edit. I see this is a 2009 purchase.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Take a look at the Musical Fidelity A5 also.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
Now that my Cambridge Audio 840C is up & running, I must say that I am extremely "over pleased" (is that possible) with it's musicality. I was not expecting anything near this level of performance even though all the reviews have stated that. And the kicker is that it's not even close to it's best sound yet! Worth a look at.
Like Steve's suggestion and throwing the Raysonic in the mix is gonna give you alot to think about.HT SYSTEM-
lsi 9's -
Vr3MxStyler2k3 wrote: »The Tri-Vista is definitely an option I will consider as Ive been very impressed at all the gatherings Ive heard it at...
The Tri-Vista is out Sid. It has a flawed transport. You would have to go with the MF kW which is pulling in around $4K used.
December, 26th I purchased a Raysonic CD 168. It plays redbook only but I swear it rivals the redbook playback of the kW. The 168 is absolutely awesome. The sheer weight of the music is unbelievable, detail, bass weight too. I bought a Denon from Bill W as I am going to use that with a MF tube buffer to play SACD and DVD-A.
I've seen the Raysonic priced from $2600 to $3600 and this is for a brand new piece. I purchased mine from Quest for Sound. Stephen Monte the owner is a great guy and will give you a great price.
It took about 100 hours to break in. I kept it burning in for another 275 hours just to make sure. Its output tubes run in single ended and balanced so it uses four tubes, 6922 EH comes stock. It runs in pure Class A.
EDIT: This all from an analog guy! -
Naim
The Rega Saturn would be on my list to listen to if I could afford it....
Just wondering aloud here but wouldn't it be better just to get a nice DAC ?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
He's heard the Rega Apollo in his rig and I wouldn't imagine that this would be one for consideration. His Shanling sounded better using the analog outputs. Not a night and day difference, IMO but a slight edge went to the Shanling.
Trey, why is Jolida not an option for consideration? It turned out to be the missing link in my rig. Incredible difference in the sound stage and harmonics. Texture? Yep. Got it. Maybe I should shoot up there and give you a chance to audition it in your rig. Food for thought, as it has incredible synergy in my rig. I couldn't be happier.
I know there is better out there, but this player did wonders to the end result and our rigs are somewhat similar. LMK.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
PC harddrive and a DAC. It's all 0's and 1's. Rip it all to a harddrive and then put your money in the DAC. As long as you have a good transport to do the original copy/rip, you then eliminate the weakness of the transport in the playback and you can swap DAC's as needed to get to the sound you like. I'm pretty old school, but after doing some research on this I think it's really the future digital playback method.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Atta guy throw a monkey wrench into my sale of the Timbre DAC!!!:p:D Now I'm thinking I should keep it for a future application you described above. It never ends.:eek: -
hearingimpared wrote: »Atta guy throw a monkey wrench into my sale of the Timbre DAC!!!:p:D Now I'm thinking I should keep it for a future application you described above. It never ends.:eek:
You should.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
hearingimpared wrote: »Atta guy throw a monkey wrench into my sale of the Timbre DAC!!!:p:D Now I'm thinking I should keep it for a future application you described above. It never ends.:eek:wingnut4772 wrote: »You should.
I can't keep it, I need to pay for the Raysonic!:( -
Wadia
Musical fidelity
Just my opinion.
+1
Or, better yet, spend the money on new speakers. IMO, that's where the nuances of music live or die. -
I'm an old school type of guy when it comes to my 2 ch system, but you just can't deny some of the developments and benefits to the hard drive or music server storage of digital music. I'm not sure I could really justify spending over about $1500 on a CDP without seriously considering the option.DKG999
Since your not buying for over a year I would just research the mentioned companies and pick'em, who knows what might come along in the mean time. A used BAT would be oh so nice the special edition with the supertube, redbook only though and you should consider Cary as well.
RT1 -
The tri-vista sounds great & it's got inputs for its DAC (so you could run a music server through there), but I've seen more than one w/ a dead transport.
Wadia is absolutely awesome- nevermind how they sound: I love the machined remotes... if anyone ever breaks into your house, just chuck that badboy in a sock and go to town!Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
The Tri Vista has nearly 100% failure rate on the transport. Once it does fail, it can't be fixed. -
I've never read a bad word on how the Wadia CD's sound. High price though.
Sorry to get off the subject, but can you real quick tell me what part of the transport goes bad? If you know, that is....
Sorry for the derail Trey. If I have another question from the response, I promise I will make another thread.
High price though.
madmax
You said a mouthful. I just saw a couple on the gon and one was over $9k the other was in the $4k zone. -
A music server and different speakers are options to consider spending your hard earned money on.
But it's your money and you asked. -
I've never read a bad word on how the Wadia CD's sound. madmax
There **** awesome sounding.
That ends that Max. Bad Word and all that.
Hell lets get the boy a DCS or Reimyo, the new Esoteric two piece is a cool 15grand.
RT1 -
I agree. A computer digital source feeding a Monarchy DIP (to remove any jitter) and then on to a quality DAC. That's my plan anyway. -
hearingimpared wrote: »The Tri Vista has nearly 100% failure rate on the transport. Once it does fail, it can't be fixed.
Weird- has that changed in the last year? I was about to buy one last Feb. w/ a dead transport and called up Signalpath and they said they could fix it.
Hell, they've even got an office in NC, which would be good for Trey.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Wadia is pretty much the pinnacle in redbook CD. If I had money falling out of my ****, I would own one.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
The guy at Signal Path is named Rick. We have two members here who owned Tri Vista SACD players and both took a dump. Musical Fidelity offered up the kW with trade in an a little moola.
The information about the Tri Vista's failing is all over the audio rags. Stereophile, TAS etc. Musical Fidelity, Krell and a couple of other manufacturers are suing Phillips because Phillips abandoned any responsibility for making good on the crappy transports that were sold to those companies.
