Electronics got wet - what to do?
Serendipity
I know this has happened to someone before so...what do you do if your TV gets wet (such as in a flooded basement) but it was powered off during the "incident"?
I was thinking of using some PCB degreaser/electronics cleaner on the boards to remove all the residue and then wait a few weeks for the set to dry?
This is for my uncle's set and I am trying to get it working.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
Sounds like a good plan. You could use a blow dryer to speed up the process. Not sure if you need 3 weeks, but a longer period of non-use won't hurt.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Lots of voltage in tv's, monitor's etc. PLEASE approach power up with caution - a variac may even be a good (safe) idea.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
You can use distilled water, and some simple green to clean the components(10 to 1) Rinse with straight distilled water. Beware of using "electronics cleaners" I have had them make a mess of my Adcom GFA-585 input boards.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
You're electronics got wet? You're lucky. Mine always has a headache.Do you hear that buzzing noise?
Call your insurance...I , myself would never play with the insides while plugged in.
I'm aware of that, 35kV is not to be treated lightly, especially in the high voltage section of TV's.polkaudio RT35 Bookshelves
Unplug and allow to dry is the first step. Afterwards use a good contact cleaner(electronics cleaner, isopropyl alcohol works too) and then try playing it.Shoot the jumper.....................BALLIN.............!!!!!
I really recommend staying away from contact cleaner. I learned this first hand. I would recommend going to DIYaudio and asking them. I learned from some real electronics repair men that solvents are a bad idea. Unfortunately I learned this after gumming up my boards, and making a mess. Simple green, and distilled water. 10 parts water 1 part simple green. Neither are conductive. Wash with a thorough rinse of distilled water.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Good info, I suggested due to what I've experienced in military. As a tech thats all we used to clean circuit cards, etc. And these cards were used in radar controllers that were used in air to ground traffic control.Shoot the jumper.....................BALLIN.............!!!!!
Monster Jam wrote: »You're electronics got wet? You're lucky. Mine always has a headache.
Priceless.... nearly sig worthy
Fixed many TV's in my day, but I'm thinking if under water... Start OVER
I'm more iffy on the flyback, any filter caps not a pretty fix and sure it's not a worth fixing it. But your plan to get rid of the residue I'm in Ben's boat... Clean water raise hose then sun or set aside for a few days. Maybe maybe but still iffy.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
LOL..you baaaaaaaaad......:eek:Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
I will find out if this works tomorrow.
Thanks guys!polkaudio RT35 Bookshelves
