Speaker Tilt...
jakelm
jakelm Posts: 4,081
edited January 2008 in Speakers
Where can I find those level doohickeys that tilt a center channel forward?
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • GZ
    GZ Posts: 343
    edited January 2008
    By forward I assume you mean downward. Have you considered using rubber door wedges? You know, the kind you put at the bottom of a door to keep it open. They're cheap and can be found at Lowes, Home Depot, or any hardware store. You probably only need 2 placed a couple inches from each side. Depending on the angle you're looking for depends on how far you slide them under the back of your center speaker.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    I'm looking for the kind that mounts on the back of the speaker to tilt it "downward". And can be adjusted.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Face
    Face Posts: 14,340
    edited January 2008
    Deck of cards.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    The bracket that mounts on the back of a center channel to tilt it down. You guys know what I'm talking about.
    Cards would work but the diamonds interfere with the frequency responce. And I believe they resonate @ 15khz. So that wont work.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    brijenjas wrote: »
    No..its a small braket that screws to the back of the center channel. It has one rubber foot and can raise or lower the back of the speaker
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Like this or something like it.,... This guy uses it on a thin tv, but if used on a flat surface it will tilt the speaker downward.
    I just dont know what its called or where to find one.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    Have you tried sitting on phone books?
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    ben62670 wrote: »
    Come on Ben..help me out here....:mad:
    I have never seen a peice of equipment I couldnt find...but this peice is driving me crazy.. Cant find anything about it.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited January 2008
    Sorry dude:(
    I'll look around.
    Ben
    tonyb Posts: 33,069
    edited January 2008
    Try mapleshade...they have stuff that will do what you want,but for me,the door wedge suggestion was damn good and cheap.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    ben62670 wrote: »
    Sorry dude:(
    I'll look around.
    I'm trying something new here and trying to look professional. I know cards, door pegs and phone books work great, but, I'm a professional (yeah right:p) I need to look like one......:o..maybe?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    tonyb wrote: »
    Ok , I 'm really suprized partsexpress doesnt have that, they have just about everything else.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Face
    Face Posts: 14,340
    edited January 2008
    Who's going to look at the back of your speakers? :D
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Face wrote: »
    Well you see, my massively huge RPTV, sticks out, and you can see almost a 360 around the center speaker, well off to the side at least. I will see if I can find small door stoppers, if I cant find this peice. There are pictures of this particualr item, so I know it exist. Some center speakers, I have noticed, come with this adjuster already built on.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    tonyb Posts: 33,069
    edited January 2008
    jakelm wrote: »
    Huh...two different companies......partsexpress and mapleshade.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    tonyb wrote: »
    I ment ok Ill check mapleshade, but I was suprized I couldnt find it @ PE
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Nope Mapleshadeaudio doesnt have it.
    Good Lord, the one and only thing I want in this whole wide world and I cant get it...:(
    Im going pout
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Polkitup2
    Polkitup2 Posts: 1,641
    edited January 2008
    I believe your photo is of an NHT center. My NHT center has a foot just like that one. They came with the speaker and I have never seen them sold separately anywhere.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2008
    you could just buy a 2-channel system and not have to worry about it.
    Problem eliminated. Audio Nirvana.
    If you insist then make your own bracket out of door style slide bolts.
    RT1
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    HaHa. And fill my walls and empty spaces with what????? Pictures????..Hell no......lol:p
    RT1
    Thanks RT1, I knew you would know the answer. Having all that experience in HT systems..:rolleyes:..:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2008
    my csi5 has the monopod built into it. but i don't like nor trust it on top of my rptv. so i custom fabbed one that angles down. it's more of a shelf with an EXACT footprint of the csi5.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    BIZILL wrote: »
    Monopod. Is that what its called? I was going to get 2 and put one on each corner for stability.
    I have a shelf thats the exact footprint under the speaker. But that is used so the speaker doesnt bowe the tv.
    You have any pics of what you did? Maybe I could grab some ideas.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Hmmmm...Maybe I can order this peice from Polk?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • reeltrouble1
    edited January 2008
    well if you wanna put something mono on your HT system go for it. :rolleyes:
    fyi I was doing multi channes when you were just a twinkle in your Daddy's eye. we just did not call it that, quadrophonic baby, pretty much sounded like **** though.
    I still like my slide bolt idea which is much more original. Hell I outta market the little sum-****. Call'em the little Slide Sumbitches Speaker Stilts, say that five times fast, audiophile tested and include some pebbles.
    RT1
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Its a stereo 2 channel center speaker.
    Yeah with that ugly delay processor. My dad was in the HiFi buisness between 1974 and 1980. He tried the quad stereo. They actually had Matt Polk and his partner at the time (I forget what his name was), come down to Lafayette Louisiana (where my dad's store was) to display and show his Polk 7's. Then they all flew to Vagas for a show.
    RT1
    I think thats alittle ahead of its time my friend...;)
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2008
    jakelm wrote: »
    Late to this post - but these doohickeys are an option.
    I use these for my PSW303 on the wood floor to keep it from jiggling and waddling about and add a bit of isolation and tilt to my room:
    http://www.truesoundcontrol.com/products/MOPAD3.html?gclid=CO6Zoe-uyY8CFRsFagodWiA_-A
    FWIW,
    Erik
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    I like that option Erik, thanks.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jam-chn
    jam-chn Posts: 6
    edited January 2008
    Hi,jakelm!
    I think if the in-ceiling spk can like this:
    http://www.erisson-spk.com/Products1.asp?CateID=106&ID=357
    30 degree Inclined plane, free adjust sound direction when installing it!
    I like music forever!
    www.erisson-spk.com
  • AudioFilet
    AudioFilet Posts: 235
    edited January 2008
    I use the Auralex MoPAD speaker pads. They not only allow for tilting the speaker, they provide acoustic & mechanical isolation:
    http://www.truesoundcontrol.com/products/MOPAD3.html?gclid=COuio_C2h5ECFTyKOAod8W6zIA
    2 Channel rig:
    LSi9"s (modified xover's) & HSU Sub
    Harman Kardon HK 990 Amp
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
    HK AVR-745 & Polk Monitor Series
