Electronics got wet - what to do?
Serendipity
Serendipity Posts: 6,975
edited January 2008 in Electronics
I know this has happened to someone before so...what do you do if your TV gets wet (such as in a flooded basement) but it was powered off during the "incident"?
I was thinking of using some PCB degreaser/electronics cleaner on the boards to remove all the residue and then wait a few weeks for the set to dry?
This is for my uncle's set and I am trying to get it working.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • joeparaski
    joeparaski Posts: 1,865
    edited January 2008
    Sounds like a good plan. You could use a blow dryer to speed up the process. Not sure if you need 3 weeks, but a longer period of non-use won't hurt.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2008
    Lots of voltage in tv's, monitor's etc. PLEASE approach power up with caution - a variac may even be a good (safe) idea.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    You can use distilled water, and some simple green to clean the components(10 to 1) Rinse with straight distilled water. Beware of using "electronics cleaners" I have had them make a mess of my Adcom GFA-585 input boards.
    Ben
  • Monster Jam
    Monster Jam Posts: 919
    edited January 2008
    You're electronics got wet? You're lucky. Mine always has a headache.
    Do you hear that buzzing noise? :confused:
  • Willow
    Willow Posts: 11,227
    edited January 2008
    Call your insurance...I , myself would never play with the insides while plugged in.
  • Serendipity
    edited January 2008
    RuSsMaN wrote: »
    I'm aware of that, 35kV is not to be treated lightly, especially in the high voltage section of TV's.
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2008
    Unplug and allow to dry is the first step. Afterwards use a good contact cleaner(electronics cleaner, isopropyl alcohol works too) and then try playing it.
  • ben62670
    edited January 2008
    Sherardp wrote: »
    I really recommend staying away from contact cleaner. I learned this first hand. I would recommend going to DIYaudio and asking them. I learned from some real electronics repair men that solvents are a bad idea. Unfortunately I learned this after gumming up my boards, and making a mess. Simple green, and distilled water. 10 parts water 1 part simple green. Neither are conductive. Wash with a thorough rinse of distilled water.
    Ben
  • Sherardp
    edited January 2008
    ben62670 wrote: »
    Good info, I suggested due to what I've experienced in military. As a tech thats all we used to clean circuit cards, etc. And these cards were used in radar controllers that were used in air to ground traffic control.
  • michael_w
    michael_w Posts: 2,813
    edited January 2008
    Priceless.... nearly sig worthy :D
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2008
    Fixed many TV's in my day, but I'm thinking if under water... Start OVER ;)
    I'm more iffy on the flyback, any filter caps not a pretty fix and sure it's not a worth fixing it. But your plan to get rid of the residue I'm in Ben's boat... Clean water raise hose then sun or set aside for a few days. Maybe maybe but still iffy.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    LOL..you baaaaaaaaad......:eek:
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Serendipity
    edited January 2008
    ben62670 wrote: »
    I will find out if this works tomorrow.
    Thanks guys!
