Hooking up signal cable on second amp
jhornsbee1
I just got a second amp, and i have everything hooked up except for the signal cable. Is the a way to run it from the allready existing signal cable, or do i need to take off the head unit again and input it to another pre-out... please help, want to be able to use my new system.
Post edited by jhornsbee1 on
just 2 make ur day so u can go and pump ya tunes, yea u can run both amps, just make sure head unit is turned off(so is no signal on remote from head unit)and link from 1 2 the other,its only small signal so no limit how many times split off. hope answered question
How would i do that, the inputs into the amp are rca, and the second signal cable is also one side rca for the amp and the other side straight wire. how would i go about jumping it from the first amp to the second?
by signal cable are u just talking about powering the amp up or imputting sound in2 via ur rca leads?just that u say u have hooked it up apart from signal?
the amp is hooked up except for the signal cable (the sound rca lead) all of the other wires are attached and ready to go
i c mate understand now u can get thin called y splitters u need two of them,one end female 2 go on2 rca and comes out as 2 male so instead 2 males end up wit 4.also some times an amp will also have rca out,another words just using amp as junction in that case just require another rca
you guys need to post this in the car audio section of this forum. here is the home audio section.. the car guys and girls can give you more information .. and probably better info too.PolkFest 2012, who's going>?
where is all car audio stuff anyway i knew this site
right here http://www.polkaudio.com/forums/forumdisplay.php?f=5
it's called On The Move for all your car audio related questions about amps, head units, speakers, etc. good people in there.PolkFest 2012, who's going>?
wicked ta dude
