More tubes! Ae Symphonies
sucks2beme
sucks2beme Posts: 5,682
edited January 2008 in 2 Channel Audio
I just picked up an AE Symphonies preamp. It currently is set up in the 2
channel with the pc/MonicaII and AR vt60 amp and Paradigm studio 60's.
It replaced a Parasound p/sp1000. So far, It sounds pretty good.
It's a bit more forward than the Parasound, but with good detail
and some interesting tube benifits. It adds depth to many stringed
instruments. So far, I've gone through two Allison Krause albums.
Next up, some rock.
This preamp has done the circuit of Polkie owners. I don't believe it has had any
of the cap mods done yet.
Post edited by sucks2beme on
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited January 2008
    Have you tried some telefunkens in it?
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2008
    Forget tubes at this point, as it's been around. It's time for MODS.
  • Early B.
    Early B. Posts: 7,900
    edited January 2008
    It's a great preamp. I'd love to hear your impressions of mods.
    "God grooves with tubes."
  • sucks2beme
    edited January 2008
    At the moment, I've got it back out of the system. The output of the MonicaII
    DAC, even with gain stage, is lower than normal. The gain on this pre is also a bit low.
    I'm going to mod it, try it with another DAC with better output.
    The recording out (to the headphone amp) is a Y connection off of
    the source selection switch. Interesting that this "passive" connection
    changes the sound, even with the pre turned off. I need to analyze the
    input of this amp a bit to find out why this happens. It would seem the
    other leg of the Y that goes through the Alps volume and to the preamp
    section has an effect. I may also change the Alps out for a stepped
    ladder, since many feel the Alps volume controls cause some bass loss.
    The joy of point to point wiring is this is moddable even by us old
    half blind guys.
