Panasonic DMP-BD30K Part II...
COOL, thanks. I was not aware of that.Since you are getting Directv (or already have?), did you know that HDNet has some test patterns that you can get to help calibrate the input for your satellite box? They broadcast them once a week, early Saturday mornings. I have them recorded on my DVR.
6:30 AM ET
3:30 AM PT HDNet Test Patterns
Wonder how your home theatre is doing? Wish you had test patterns to help set it up? Well, HDNet is here to help. This short program will help you get the most out of your home theatre setup by providing you with the same professional test patterns HDNet uses to set their gear.
Its 10 minutes long, so record from 6:30-6:40am ET on Saturday morning.
The standard def DVE (I'm sure Avia as well) works fine for all the basic settings; Bright/Cont/Color/Sharpness/Tint, etc. It made a world of difference as the settings were alot different from my Denon.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
