monitor 10s
enaylor
enaylor Posts: 2
edited November 2001 in Technical/Setup
Does anyone know where I can get appropriate speaker specs for these speakers.
I would like to build new enclosures and would like to plug speaker numbers in to a computer design program.
Eric
Post edited by enaylor on
  • joelll
    joelll Posts: 120
    Hello,
    These specs are from product line literature that includes the Monitor 10 (before it became 10b) along with the rest of the Monitor line at the time. (Monitor 12 had become 12b and is also referred to in this piece of literature as RTA12b). There's no copyright date.
    I hope they help; I don't quite know what info you need... but since the cabinets for the Monitor series speakers are pretty solid to begin with, I wonder what you're planning to build..
    Some of the specs sound a little weird, like the frequency range reported as +/- 2dB with no additional information, and the "System Resonance" rating.
    (per speaker)
    Driver complement:
    1 @ SL1000 tweeter
    2 @ MW6500 midrange
    1 @ SW100 passive radiator
    Cabinet size: 28" high x 16" wide x 11.5" deep
    Shipping weight: 50 lbs
    Frequency response: 22 Hz to 25,000 Hz
    30 Hz to 20,500 Hz +/- 2dB
    Recommended amp power: 10-200 wpc
    Crossover frequencies: 60 Hz and 3,000 Hz
    Impedance: 6 ohms
    System resonance: 20 Hz
    Maximum output level: 112dB
    Finishes available: Furniture grade walnut or rosewood vinyl, real walnut veneer
  • gidrah
    gidrah Posts: 3,049
    .Great post joelll!
    The drivers for the 10Bs are different than the originals.
    SL2000x1, MW6503x2, and a 10" passive (could be the same). It also uses a different crossover.
    Are you rebuilding your current cabs? If you're building from scratch, good luck. There was a pair of model 10s for sale at an awesome price. I'm thinking about selling my 10Bs, but it'll cost more to pry them from my ears. That scoundrel:)
    Make it Funky! :)
  • enaylor
    enaylor Posts: 2
    Thanks for the posts
    It looks like I have the 10bs
    I picked these up for 50 bucks but cabinets are thrashed so thought I would build new ones maybe different dimensions with same air space. taller thinner .
    Eric
