Tranny rebuild or replace?
Have you considered a remanufactured transmission?
Rebuilt is just worn parts replaced with new parts and new seals.
Remanufactured is basically a new tranny inside a used housing.
It's better than a rebuild and cheaper than a new transmission.
UM...... NO... -
If you can get a used one installed for $1,000 (parts and labor), that is the route I would take. The dealer wants $3500...that's a $2500 difference!! Definitely worth the gamble on a used unit. Even if the used one craps out in the first month, you would only have to pay for the labor, not the trans. Basically if a used one lasts the first month, it should be good for much longer, and I'm sure it will last until you've paid off the truck.
Make sure you flush out the cooler lines to the radiator, or better still, install an aftermarket cooler.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
John, did you check with Glen Burnie Transmission?Political Correctness'.........defined
President of Club Polk -
I would rebuild it with the intent to trade it in after you get into your new home. The warranty should cover you until then.Shoot the jumper.....................BALLIN.............!!!!!
rebuild and then sell your Ford in 11 months.My Home Theater (WIP):
Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
Receiver: Denon AVR-1905
Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
Dual Subs: PSW202, and behind the couch Denon 8"
My showcase link:
Media Room pics -
I don't know about Ford, but my Honda had a 10 year/100k mileage warranty on the drivetrain...........if Ford has that, how do they consider the tranny NOT a part of that system? (I didn't see you mention how many miles are on it other than at 75k you had some issues)
I would go for the new one personally. If you're planning on keeping the car just until the payments end, then you can sell the car with the warranty on the transmission (assuming it's transferrable) and ease someone into taking that thing off your hands.......comment comment comment comment. bitchy. -
Honda works hard for their Public Relations so when Honda had a problem with their new 5 speed auto transmission, they did the right thing. The transmission warranty was changed 50k to 100k mileage, there PR is more important to them then $. IMHO
So what is Ford doing?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
