RTI10's and Onkyo tx-sr605
Mauskar
Mauskar Posts: 104
edited January 2008 in Speakers
Hey guys,
I wanted to know if anyone here has the RTi10's and the onkyo 605. I recently got the the 605 as a gift and purchased the RTi after auditioning them at Sound Advice.
I am just wondering if the receiver is adequate enough to power those speakers- according to polk tech, the 7" woofers draw alot of power.
Let me know as I am thinking of either upgrading to a 705 or 805- would the 705 be enough?
Thanks!
:confused:
Post edited by Mauskar on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    Welcome to Club Polk. The answer is not a bigger receiver, but an amplifier.
    Ben
    Ben
  • Mauskar
    Mauskar Posts: 104
    edited January 2008
    Thanks Ben,
    But the problem is the 605 doesnt have any pre-outs. Thus cant attach an external amp to it.
  • ben62670
    edited January 2008
    OK. Can you upgrade to an HK with pre outs? Ebay store Harmon Direct has good AVRs with PreOuts for around $300. Take the extra money, and get a used amp. Don't get hung on watts. A receiver compared to an amp is like comparing a car audio head unit to a separate amp.
    Ben
  • Mauskar
    Mauskar Posts: 104
    edited January 2008
    Oooh. Didnt think of that option. Which HK receiver and what amp? sorry but im a newbie and med school takes all my time. HDMI in the receiver?
  • ben62670
    edited January 2008
    I really don't care too much about HDMI in the receiver. Many others will probably chime in on this as bad advice, but my logic suggest going directly to the TV with the HDMI. If HDMI is needed others that know more than I do in that department will help. I was using an HK AVR-235 as a pre for a while. It is "only" 50 watts per channel, but is fine for center, and surround duties for most users. With the AVR doing C/SR/SL duties with the speakers set to small, and an amp running fronts set to large worked excellent. My main amp was 250 watts per channel. I did have to turn the fronts down 3-4db for movies, but when listening to music in 2 channel the amp really lets those larger speakers shine.
    Ben
  • Mauskar
    Mauskar Posts: 104
    edited January 2008
    Hmm. Was looking for HDMI in the receiver. But love HK receivers.
    Ben, you're in FT. lauderdale? I actually live in Miramar. Got my RTI's from sound advice in aventura.
    So does anyone have a setup with RTi10's and the onkyo 605's- just want to know if its common. My system sounds "harsh" but havent tuned it completely.
  • ben62670
    edited January 2008
    http://stores.ebay.com/Harman-Audio
    Take your time, and get a good deal. Don't jump on the first deal you see. It looks like $350 will get you into something good.
    Ben
  • ben62670
    edited January 2008
    Hi neighbor:D
    Ben
  • Mauskar
    Mauskar Posts: 104
    edited January 2008
  • ben62670
    edited January 2008
    Look for HK AVR-247, and up. They have HDMI, and pre outs. If you take your time, and make some offers you should hit it around $300-350.
    Ben
    tonyb Posts: 33,068
    edited January 2008
    Be more specific.....a seperate amp will help,how are they set up? Room size,feet from rear and side walls,listening position,size of room,and so on.Whats the other gear? Do you have a sub? To me,the oyk and the RTI line are not the best of matches.Both on the brite side.
  • Mauskar
    Mauskar Posts: 104
    edited January 2008
    tonyb wrote: »
    the receiver is setup according to factory instructions- no amp, and cant connect to one since there are no pre-outs. Here are the other things you asked for:
    Room size: 14'X22'X20
    Listening position= 9ft
    Distance btw speakers= 9ft
    Distance from rear wall= 1.5ft
    Distance from side wall= 2ft
    Other gear is:
    42" Sony Wega rear projection 720p
    Sony DVD player with HDMI
    Comcast DVR
    XBOX 360
  • iskandam
    iskandam Posts: 704
    edited January 2008
    I used to push an all-R series with my Onkyo 605 but that combination proved to be too bright at louder volumes so when I upgraded to an all-RTi set up I picked up a Harman Kardon AVR 247 and it proved to be a much better match. The amp section of the HK is actually quite robust, so even though it's rated at 50 wpc the actual SPL output is comparable than the Onkyo and I actually prefer the HK sound better. Not only that, it's also a lot more customizable than the Onkyo and has flexible bass management settings for each channel, which you'll find handy with the RTi10
    I'm in the process of getting a multichannel amp to get that extra kick in clarity and detail based on everybody's recommendation here :D
  • avguytx
    avguytx Posts: 1,628
    edited January 2008
    You could always use the Zone 2 preamp output from the TX-SR605 to run to a separate amplifier. Just a thought...
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • bopicasso
    bopicasso Posts: 878
    edited January 2008
    Would that work to use another amp? Usiong the Zone 2 preamp output??? Because I have the onk 605 also. I was thinking about selling it and getting something different because of all the negative reviews about not having preouts. But im only running rti6's for main speakers and a csi3 for center.
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • HWNBOY
    HWNBOY Posts: 9
    edited January 2008
    Did anyone already answer the latest question from "bopicasso" regarding the onk605/rti6/csi3? May be I missed it. I have the Onk605/csi3/velodyne sub/rti8 (just ordered this) .. and I am fearing that I pulled the trigger to early on the RTi8s because the receiver I got. Anyone? Thanks.
