Wall mount for Rti4's
Acadian
Acadian Posts: 60
I'm looking for suggestions on a wall mount to support these speakers (used as rears for 5.1)....2 feet above ears, 90-110 degrees from center channel.
Thanks!
Rti8
CsiA6
Rti4
PSW505
Yamaha 6050
Post edited by Acadian on
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2008
    B-tech BT77.
  • Acadian
    Acadian Posts: 60
    edited January 2008
    Thanks Dorokusai....i was just gonna ask about those.
    I read that the speakers should be 2 feet above ears and equal or a few feet behind (90 to 110 degrees). I saw a few threads where people were reluctant to drills holes in their speakers (to make sure they stay on the mounts when tilted downwards).
    So my questions are:
    1) Would **** them in place harm the Rti4 in any way?
    2) Is it necessary to tilt them downwords? (diagrams i saw for speaker placement didn't specify)
    Thanks!
    Rti8
    CsiA6
    Rti4
    PSW505
    Yamaha 6050
  • dorokusai
    edited January 2008
    I've used these for years on my front loudspeakers, using downtilt and have never had a problem. I check them every now and then to ensure they are tight and they always are. I don't believe it's neccesary to drill holes.
    You could tie a thin dress shoelace around the binding post, then the mount if you are concerned.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2008
    I've got RTI4s for Fronts and Rears in my 5.1 setup.
    For the fronts I'm using the B Tech BT-77 mounts seen here:
    http://erikt.cts.com/Pictures/hometheater/home-theater-1.JPG
    Totally satisfied with the mounts and you do NOT have to drill into the cabinets to get a secure fit.
    The B Tech BT-77s do allow a downward tilt - so it depends on where you have your speakers mounted and where your listening positioning is.
    For the rears, I do not have a side wall as my family room is open on one side to the kitchen, so I had to ceiling mount the rear RTI4s.
    For that application I used the Ominmount 20.0 (rated for 20lb speakers and I weighed my RTI4s at 11lbs). This is also a good mount, imho and also allows for adjusting angles. I've got the RTI4 rears angled down and towards my listening spot.
    Cheers,
    Erik
  • dorokusai
    edited January 2008
    Great post Erik, thanks!
  • Acadian
    Acadian Posts: 60
    edited January 2008
    Thanks for the info guys!
    I bought the BT-77 and put them up on the wall this weekend. A bit pricey, but they seem like a very sturdy product. Finding the studs behind the wall, measuring where to install, etc. took some time, but the product itself was a breeze to install!!!
    I haven't put the speakers on them yet (i am waiting for the wires anyway). I might use the shoelace idea just for peace of mind :)
    Cheers!
    Rti8
    CsiA6
    Rti4
    PSW505
    Yamaha 6050
  • dorokusai
    edited January 2008
    That's a great mount, get those speakers mounted! :D
  • mantis
    mantis Posts: 17,329
    edited January 2008
    Something wrong with keyhole mounting? With proper placement, you need not tilt them anyway. I mount them all the time with the keyhole.
    Dan
    Dan
  • dorokusai
    edited January 2008
    Something wrong with getting the loudspeaker aimed at the listening position? If I keyhole mounted my front speakers they would be shooting over my head....not a great way to create a convincing front stage.
    I can see your point in regards to surround placement but isn't that up to the end user? Just because it might go against a Dolby/DTS suggested mounting position doesn't mean it's wrong.
  • brittmer
    brittmer Posts: 11
    edited January 2008
    mantis wrote: »
    Dan
    I have my Rti4's mounted from the keyhole. My mounts aren't made for the weight of the Rti4 but I have the bottom of the speaker resting on the wall which gives me the down angle that I need. They have been hanging there without any problems for 2 years.
  • Acadian
    Acadian Posts: 60
    edited January 2008
    dorokusai wrote: »
    I'm not sure what this means? I read a few sites on speaker placement and followed what they said....i'll google dolby :confused:
    Rti8
    CsiA6
    Rti4
    PSW505
    Yamaha 6050
