Looking at some SDA(s), should I????
    heiney9 Posts: 25,406
    edited January 2008
    danger boy wrote: »
    high 5, finally someone making sense.. i knew they were 2B's. but does anyone listen to me??? :rolleyes: :p
    I'm always listening DB :D.
  • Marty913
    Marty913 Posts: 760
    edited January 2008
    danger boy wrote: »
    Did you say something ?:rolleyes:
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • Windwalker
    Windwalker Posts: 46
    edited January 2008
    Picture of Speakers are HERE
    I think the "B" on the back maybe even more of a clue as to what they really are
    They are wood tops, painted black.
    Serial number is 21397
    Do all these have cloth inserts on both sides?
    So final agreement is that these are 2B studios-correct???
    Some of the worst wrongs get righted on three cords
    edited January 2008
    Some of the very late run 2's and 1's had a sticker on the label (added after the fact). My 1C's have a "C" sticker as well but you don't often see that.
    Those are "regular" 2B's and someone painted those end caps. If Polk had offered "black ash" from the factory (for non-studio models) they would have been laminated not painted.
    You got a good deal on a great speaker. With a little TLC and some future upgrades (tweeters and x-over) you will have a speaker not many manufacturer's today could touch.
    edited January 2008
    Windwalker wrote: »
    Yes they have cloth inserts that can be very very carefully removed if they need to be re-clothed. They are glued on and it takes great care and patience to remove them without damaging them. It is common for this age of speaker for them to start to pull away around the edges.
    No they are not Studio's. They are the slightly more expensive regular cabs with the end caps painted by a former owner.
    Also note the studio version(s) don't have the cloth side inserts among a few other visual things.
  • Windwalker
    edited January 2008
    heiney9 wrote: »
    And they did a fine job, I see no drips\runs\overspray ANYwhere(is it possible they were stained black from Polk?)
    heiney9 wrote: »
    cloth is in Great shape, slightly loose at one corner only
  • Windwalker
    edited January 2008
    I'm going to hook these up to my Yamaha HTR5460(for now) on the B main side
    It's rated as follows-
    Min RMS @.06 THD, 20HZ-20kHZ
    100W+100W 8ohm
    edited to add
    Minimum RMS Output Power per Channel MAIN, 1kHz, 0.09% THD, 8 ohms - 110W + 110W
    CENTER, 1kHz, 0.09% THD, 8 ohms - 110W
    REAR, 1kHz, 0.09% THD, 8 ohms - 110W + 110W
    Dynamic Power per Channel MAIN, 8/6/4/2 ohms - 130/150/190/240W
    These are 4ohm speakers-correct?
    My AVR has an impedance selector switch with the following
    To the Left
    Main-If you use one set of main speakers, the impedance of each speaker must be 4ohm or higher.
    If you use 2 sets of main speakers, the impedance of each speaker must be 8 or higher
    Center Impedance must be 6ohm or higher
    Rear the impedance must be 6ohm or higher
    To the right
    Main-If you use one set of main speakers, the impedance of each speaker must be 8ohm or higher.
    If you use 2 sets of main speakers, the impedance of each speaker must be 16 or higher
    Center Impedance must be 8ohm or higher
    Rear the impedance must be 8ohm or higher
    Currently switch is set to the right
    I need to change this to the left position and make darn sure I don't ever have both A&B selected.
    switching to the left will not affect current set-up (5jrs-rear,R50-mains,sub-M&K V75,center-CS101)
    Just don't crank it quite as hard
