SPL meter ??
NeilGabriel
I was looking at articles on SPL meters and one suggested that it was best to get one that gave readings at different frequency levels. If I am only setting channel volumes based upon test tones, do I need something with this ability? Thanks.
Not sure I understand this; any SPL meter will give you the Sound Pressure Level of the sound, no matter what the frequency is..... If you want measures at different frequencies, then you get a CD of test tones at different frequencies, and use the same SPL.
Measuring at different frequencies is usually used to test frequency response of speakers/room, blend subwoofers, etc.
For channel calibration, you do not need different frequencies; the test tones of the AVR will be enough (and you can use the Radio Shack SPL meter)._________________________________________________
All you need is a basic RS meter like Ricardo suggested. This is the one I have, and the analog meter is great for precise readings.
One point of clarification ... I have always understood that if you are using the analog Radioshack SPL meter, there is a set of corrections that need to be made at certain frequencies. For example, the low frequencies always show up low on the SPL meter and you need to add a few db's to the readings in order to actually have the same SPL across the frequency band.
There are quite a few correction tables on the web and I've read this from a number of people on a number of different forums. I've always used the correction table when I calibrated ...My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
I have both the analog and digital version of the shack meter....never far
In this pic as a matter of fact.....I think what you were referring to was the A and C weighting...not just DB level alone but the frequency spectrum included in the measurment.The first rule of Fight Club is you don't talk about Fight Club -
Totally. I used the C weighting, and I just worry about main speakers for making sure the volume is equal. I adjust the subs with my ear because I think that is easier then charts and what-not.
+1
The only thing I found the SPL meter good for in regaurds of subs, is Fr sweeps peaks and nulls and phase callibration, But the ear is used in "blending" the sub with the rest of the system. Although my HK EzEq does a good just at callibration. But I always go back and check.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
I have the Rat Shack digital. I set it to "c weighted" on slow response. It works very well. I like the digital over the analog for the slow response setting, and it is easier to record on paper the readings you get in a sweep. Also check SVS website for calibration on the lower frequencies. Both meters are off up to about 12db at the lower end.
Ben -
Interesting stuff
http://www.svsound.com/questions-faqs.cfm#meter
Calibration table
http://www.svsound.com/questions-faqs-rscomp.cfmPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
For the tweakers there is a relatively easy modifcation available for the rat shack meters that give them flat response to 20hz so that correction tables are not needed.If anyone is interested I will dig up the link.I did the mod on my old analog unit and it worked as intended.Testing
Testing
Testing -
Here is the procedure for the old analog meter. http://mysite.verizon.net/tammie_eric/audio/rsmeter/33-2050/33-2050.htmlTesting
Testing
Testing -
Sweet link.
I still like the SVS correction table. Its easier than modding a stock meter, but if you are into a lot of DIY projects curing the swing at higher frequencies sure would be nice:)
BTW the digital, and analog are only a $5 difference.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
There is also mods for 2 other RS units.Sweet link.
I like to be able and take a direct reading from the meter and write it down instead of having to add a correction factor.I still like the SVS correction table. Its easier than modding a stock meter, but if you are into a lot of DIY projects curing the swing at higher frequencies sure would be nice:)
I use these test tones http://www.realtraps.com/test-cd.htm from the Real Traps site because they are in 1hz steps from 10hz to 300hz.Testing
Testing
Testing -
Yes tis a mild inconvenience. I use an excel spread sheet to help in that department. I will look into the mod for the digital though. I need better/stable readings in the 2000-3500 range.
Ben -
GV you da man!
http://mysite.verizon.net/tammie_eric/audio/rsmeter/33-2055/33-2055.html
Thanks Much. I have to get my read on!
Ben -
I did not do the hi frequency mod on mine yet, but yeh it would be great to have the ability to do accurate measurements when do crossover design.I will look into the mod for the digital though. I need better/stable readings in the 2000-3500 range.
BenTesting
Testing
Testing -
GV you da man!
Ben
X2 for GV...I have my analog meter modded but I didnt know you could do the digital version...gonna be done now....thanks
If anyone is interested, you can still get the old RS analog meter that the mod article refers to. Cheap too:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92282 -
Wow good find.If anyone is interested, you can still get the old RS analog meter that the mod article refers to. Cheap too:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92282Testing
Testing
Testing -
These meters say they have various ranges, e.g., 7, is this a setting for distance from source?
NeilGabriel wrote: »These meters say they have various ranges, e.g., 7, is this a setting for distance from source?
No, the analog models have a -10 to +10 range where the little pointer thingie moves back and forth... and then you have to set the SPL meter to the range that you are trying to measure. e.g. set it to '7' to measure from 60-80 dB, set it to '8' to measure 70-90 dB, etc.My HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
dB ranges, not distance. Like jw said, but I think mine is -10/+6 isnt it?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Yup, you are right ... it is -10/+6. Leave it to Radioshack to come up with such a nonsensical +/- range.
My HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
