RTi equivalent Center Channel that's less than 19" wide
louieeg
louieeg Posts: 5
edited January 2008 in Speakers
I have a dilemma. I have RTi10 fronts, and fxi3 rears, but my center channel is a CS1. The reason for the CS1 is because it's only 18" wide, and it fits perfectly in my wooden tv stand. I'd prefer to not put a center channel on top of the tv for aesthetic reasons. Is there another brand center channel that is less than 19" wide, that would match the RTi series? I don't believe Polk makes a center that's less than 19" wide besides the CS1 and the VM series.
Post edited by louieeg on
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2008
    I wouldnt mix and match the front soundstage, keep the Csi3 and find a way to make it work. I would actually recommend the larger Csi5. Good luck on quest though. Sounds like a great theater in the process.
  • Willow
    Willow Posts: 11,219
    edited January 2008
    You could use a rti4 or 6 and lie it on it's side?
  • SolidSqual
    SolidSqual Posts: 5,218
    edited January 2008
    Willow wrote: »
    RTi6 would be a good option.
  • Willow
    edited January 2008
    I'm even thinking of using one or two as my mains as I can't seem to get a good deal on a used csi5.
  • louieeg
    louieeg Posts: 5
    edited January 2008
    Willow wrote: »
    hmmm....that's a good idea. I believe these are sold in pairs. does anyone have 1 for sale? or want to split a pair? :D
  • louieeg
    louieeg Posts: 5
    edited January 2008
    Willow wrote: »
    how would 2 rti4's sound as a center channel? That might actually work in my tv stand. The same # of mid's as a csi3, but twice the tweeter! I think i'll give it a shot.
    Has anyone tried this? This should be easy to compare for anyone with a csi5 and rti4 surrounds.
  • mrloren
    mrloren Posts: 2,474
    edited January 2008
    I think you can still get a pair of rti4's at frys for $149. thats cheaper than a csi3
  • xMEATx
    xMEATx Posts: 15
    edited January 2008
    Check Outlaw Audio, they are going to release a center speaker that is 19" wide. All of their components are quality and customer service is great. I think it sell for around $600.
  • CAvolleyballguy
    CAvolleyballguy Posts: 156
    edited January 2008
    Hey all..
    I am currently using my one rti6 as a center to match my front 10's. (my csi5 arrived broken, so I am waiting on a new one)
    The minute I plugged it in....I could hear the difference ( i was using one of my bose cubes as a center...laughable now i Know)...It totaly matches the 10s...great solution...but i'm still getting the csi5....
    as I was sitting in my "ghetto home theater" (no room for the 10's the rti6 or the amp sitting on the hardwood floor...as I am waiting on moving all the stuff to the new living room) it occured to me... that although my set up looks quite ghetto at the moment... it frikin rocks...cant wait till I am in the new living room...
    Rti10 front, csi5, Rti6 surrounds, PSW505, B&K200.7s2, Onkyo705.
