Signal Cable Ultras vs. Monster Cable Z2 Reference
cambir
cambir Posts: 1,046
After winning Sherard's holiday karma for a pair of Signal Ultras, I decided a comparison would be the best way for me to fulfill my requirement of posting a review of the new cables.
I started my comparison by performing an A/B test with 2 pair of RT800i hooked up to a Sony STR-DG800 avr. I then switched the sets of cables between the pairs of 800s to eliminate any speaker differences as a potential issue.
At first listen, the Signals seemed to calm the highs on the RTs to a more reasonable level (sometimes those tri-lams can be a bit too much) and boost the clarity and definition of the instruments.
I always considered the Monsters to be very detailed and crisp, as they presented very clear highs and seemed to not lack in bass. However, now it seemed they were a bit muddled in the midrange, and a little boomy at the low end compared to the Ultras.
After this initial listening test, I could conclude the Signals were better than the Monsters, but I had expected a blowout. I just wasn’t overwhelmed with the improvement.
Because I was hoping for more, I decided to repeat the A/B test with the same RT800i pairs, but with a Yamaha R-V1105 avr (I know another avr, but no separates in the rig yet). When I initially turned on the Yamaha and started listening, I was a bit shocked. I began frantically switching A to B to A and back…there was quite a significant difference in sound on this receiver, but I couldn’t quite pinpoint the difference. So, I did what every married electronics addict does…I asked my wife. :D She hates it when I do that. I said “do these sound different to you” as I switched A to B, then back. She indicated they did sound different, so I asked her to describe the difference. In reference to the sound coming though the Monsters, she said “you turned something off…part of the music is missing.” …I couldn’t have said it better.:cool:
I’ve since had the chance to listen to the Signals for hours of music and movies and am very content to leave these hooked up to the mains in the HT/Music rig and move one of the Monsters to the center channel to replace the cheap speaker wire previously feeding it.
Bottom line: The Signal Cable Ultras are clean, warm and natural sounding cables that give music more definition and clarity than I‘ve ever heard. The Monster cables sounded great to me before my “reference” changed - they are in no way a “throw-away” set of cables, I just now know there are good cables and there are better cables…and cost is definitely not the indicator, as I’m sure these Monsters were much more retail than the Signals (though I didn’t buy them…came w/speakers on CL). If you’re in the market for speaker cables, stop shopping and buy some Signals.
Now, thanks to Sherard (karma Signals), Dave/daboyz (AQ and BJC) and all of CP, I suppose I’ll have to eventually step up the rest of my cabling…slowly, but surely.
Cables DO make a difference!
Post edited by cambir on
  • SolidSqual
    SolidSqual Posts: 5,218
    edited January 2008
    Frank Dai is my budget Hero . . .
  • dorokusai
    dorokusai Posts: 25,633
    edited January 2008
    Thanks for the post Cambir :D
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2008
    Excellent review Cambir, glad the Signals made a difference in your setup. Enjoy, they should last you a long time.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    How long did you run the Signals for? I am not sure about that particular set of wires, but some wires take a while to burn-in. The silver speaker wires I build are thin in the bass at first, and sound very detailed but gritty for about 80hrs. Let us know. Thanks for the review.
    Ben
    Ben
  • jwhitakr
    jwhitakr Posts: 568
    edited January 2008
    Nice review Cambir. Was an interesting read.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • cambir
    cambir Posts: 1,046
    edited January 2008
    ben62670 wrote: »
    Ben
    I've probably only had them running for 15-20 hours so far. Not sure how long Sherard had them going, though?
    Good info to know, will post here if I hear a change in the near future. Thanks!
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    It's about time!;):D Great review and glad you're enjoying them. We are learning here together, my friend.:)
  • steveinaz
    steveinaz Posts: 19,546
    edited January 2008
    cambir wrote: »
    I have always found thick-gauge multi-strand cables have a muddled midrange. I don't know how else to describe it. There's just not much destinction between instruments--everything seems mashed together. As far as bass, I was a little confused about wether I was hearing more bass, or just less controlled bass--now I believe it's the latter.
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    We agree Steve, even the Monster sub cables sound that away. Bass is horrible compared to better cables.
  • cambir
    cambir Posts: 1,046
    edited January 2008
    Lasareath wrote: »
    Thanks for the review Cameron, I just got in the mail 20 minutes ago (2) pairs of Monster Z3's
    I have regular monster cables right now on my 1.2tl's
    I hope to buy Signal Cable Silver Resolution Reference Speaker Cables next, But since I am Bi-Amping and my amps are 5' apart I need (2) Pairs 10' long. That'll cost me $750
    So, that'll have to wait untill after I get married,
    I got the (2) Pairs of Z3's @ 10' long with Monster Spades for $221 shipped.
    Sal
    I'd be very interested to hear your impressions of the Monsters...I still think they sound good, just not as good. My Z2s are a little older models, so I don't really know the difference from your Z3.
    Enjoy for now, but save up for those Signals! :D
  • cambir
    cambir Posts: 1,046
    edited January 2008
    steveinaz wrote: »
    Very little distinction. I would agree with the later also...less controlled bass. The Monsters have the bass, just not tight bass.
    Are Signals not multi-stranded?
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited January 2008
    Very good write up...I recently picked up a pair of Signal Ultras from SoildSqual...They are running the top end end of our RTi12's that are bi-amped.
    The bright tweeters in the recent RTi Series have disappeared...smoothed and mellowed by the help of the Ultras...without losing any definition in the mids.
    I'm planning on upgrading all the i/c's and speaker cable in the HT rig with Franks handy
    work.
    Good stuff
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Thanks for the comparison Cambir. It is always nice to hear these things. (especially as a cable builder!)
