question for mac
Kinetic
apparently the mono Amp should be here by next week, it takes too long for the holidays and those things, and the enclosure is already done, so i would have my sub playing in a few days.
anyway you told me before to take out the rear speakers, for a better SQ
but i want to know why does the rear speakers affect my SQ.
and if i take them off, am i going to have more bass on the cabin?
since the subwoofer its in the trunk, and without the rear speakers, i would have a conecction between the trunk and the rear speakers?
or its a bad idea?
thanks Mac
or its a bad idea?
thanks Mac
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Polk Audio SR 6500
G35
Post edited by Kinetic on
the reason for only front speakers is sound stage.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
i got more bass when i removed my rear speakers
Most SQ people don't like rear speakers because it changes the staging of the whole system. If you don't know what staging is, it's basically recreating instrument placement, speaker placement and ambience of the original performance or recording. Rear speakers detract from that except in the case of some SQ competitors. Now, keep in mind that if you aren't interested in creating a great soundstage, then rear speakers can sound good. You just have to follow the same guidelines as for front speakers...good quality, clean power and careful tuning. Quite a few people do see a gain in bass if they have subwoofers in the trunk since removing the rear speakers allows for more sound to pass from a well sealed trunk into the passenger compartment.apparently the mono Amp should be here by next week, it takes too long for the holidays and those things, and the enclosure is already done, so i would have my sub playing in a few days.
or its a bad idea?
thanks Mac
EDIT: I just noticed where you mentioned a concern about an connection between the rear speakers and subwoofer in the trunk. I have heard of subwoofers creating enough pressure to interfere with the rear speakers if the rear speakers and in the rear deck and the subwoofers are in the trunk. -
woow
thanks guys, i will try them in a few days.
and if i take out the rear speakers i can bridge my amp to a 100 RMS per channel, and put the gain in a quart, so 100 RMS per channel and no distortion.
thanks for the advicesZ
Polk Audio SR 6500
G35
KnuKonceptz MKS Kable -
also what if i put the four speakers in the front?
two on the regular place, and two on the kick panels?Z
Polk Audio SR 6500
G35
how much more bass?
like a 30%? or less?Z
Polk Audio SR 6500
G35
just get another sub if u want more bass...2013 Toyota Prius
Mosconi 6to8 v8 -
anyway you told me before to take out the rear speakers, for a better SQ but i want to know why does the rear speakers affect my SQ.
2 things, imaging and cancellation.
Having rear speakers will pull the soundstage to the rear when it should be right in front of you and nice and high. Also, having the rear speakers playing the same frequencies as your front speakers but hitting your ears at different times can and usually does cause cancellation not only in your ears but it also can cause cancellation in the low end response when they cancel each other out.and if i take them off, am i going to have more bass on the cabin?
or its a bad idea?
thanks Mac
That wouldnt really make much of a difference.also what if i put the four speakers in the front?
Bad idea for the same reason as rear speakers. You dont want too many speakers playing the same frequencies.polkaudio sound quality competitor since 2005
thanks a lot mac.
i already bridge my Amp in to 2 channels, and take out the rear speakers, im just waiting to install the mono amp.
and the crossover is already on 100hz for the front speakers, and i will put the sub from 30 to 100hzZ
Polk Audio SR 6500
G35
30-100? Thats kinda weird.
30 is way too high to be cutting off for the sub. There is a lot of information and "feel" in the 30 and below range. And 100 is way too high. Thatll be way too boomy and pull to the rear a ton.
Id let the sub roll off on the bottom end naturally and I wouldnt take the low pass any higher than 80.polkaudio sound quality competitor since 2005
so 20 to 80hz
and thanks again for the advicesZ
Polk Audio SR 6500
G35
Actually I wouldnt cut off the subs low end at all. Let it roll off naturally. And dont be afraid to tune around with the thing. 80 may be too high for you. Itll depend on what music you like and what sounds good to you. For instance, mine is set at 63.polkaudio sound quality competitor since 2005
ok that should be a nice task for me
i will try 60, 70, and 80hz.
thanks again for your knoledge, and for all the comments guys
i certanly learn a lot hereZ
Polk Audio SR 6500
G35
