Center speaker started crackling on my RM10 5 pack
kidgoku
Had it 6 days and just started happenings, Happens at At volume -50.
Any advice?
And using the speaker mic to calibrate, Front speakers give an error, I assume you need all 7.1 to calibrate?
I plugged all my RM10 speakers to the surround outputs on my receiver leaving the 2 fronts empty assuming those outputs are for big speakers.
Any advice?
Post edited by kidgoku on
Plug 2 speakers in to the front, then move the other 2 into the surrounds. If you only have 5 speakers, leave the 'surround back' empty.
Please reply with all components involved , including receiver model #I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Pioneer 7.1-Channel XM Ready HDMI Receiver VSX-917V-K
and 14 gauge Wire
I moved the front surrounds to just front and left the other 2 surrounds back.
earlier it still did it.
It might of only does it playing through my PC, As i did system restore, Playing the same song, I can't notice it anymore.
I had sampling rate at 192khz, Now it's back at 48khz, Was trying to get optical to work, But couldn't.
If i notice it again, I'll reply back.
