Center speaker started crackling on my RM10 5 pack
kidgoku
kidgoku Posts: 8
Had it 6 days and just started happenings, Happens at At volume -50.
Any advice?
And using the speaker mic to calibrate, Front speakers give an error, I assume you need all 7.1 to calibrate?
I plugged all my RM10 speakers to the surround outputs on my receiver leaving the 2 fronts empty assuming those outputs are for big speakers.
Post edited by kidgoku on
  • obieone
    obieone Posts: 5,077
    edited January 2008
    Plug 2 speakers in to the front, then move the other 2 into the surrounds. If you only have 5 speakers, leave the 'surround back' empty.
    Please reply with all components involved , including receiver model #
  • kidgoku
    kidgoku Posts: 8
    edited January 2008
    obieone wrote: »
    Pioneer 7.1-Channel XM Ready HDMI Receiver VSX-917V-K
    and 14 gauge Wire
    I moved the front surrounds to just front and left the other 2 surrounds back.
    earlier it still did it.
    It might of only does it playing through my PC, As i did system restore, Playing the same song, I can't notice it anymore.
    I had sampling rate at 192khz, Now it's back at 48khz, Was trying to get optical to work, But couldn't.
    If i notice it again, I'll reply back.
