Building a HT setup piece by piece.
BeRad
BeRad Posts: 745
edited January 2008 in Speakers
I have a set of R50's that have treated me well with my old AVR and junk center (20 bux 2 years ago). I picked up a Yamaha htr6090 for 600 dollars on boxing day and am now building up my system.
I have decided to get the PSW505 sub and probably the CSi3 center.
I am also looking at Rti4 or Monitor 40's for rears.
I am going to hold off on the surrounds for now but hopefully a set of FX's down the road (from what I am reading they seem to be a good choice for surrounds)
In the future I will probably upgrade the R50s before getting surrounds. Right now my mentality towards the speakers I am buying in the next couple of weeks: I want to get something that isn't too much more than I need, but will last me and keep me satisfied with the system.
Any opinions would be appreciated.
Post edited by BeRad on
  • beardog03
    beardog03 Posts: 5,550
    edited January 2008
    What kind of budget are we looking at ?
    Welcome to the forum....
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • BeRad
    BeRad Posts: 745
    edited January 2008
    I am not too concerned with matching the r50's because they will be replaced some day. i would rather get some rears that are a better match for some slightly better polk fronts than have to worry about replacing all the speakers when I upgrade the fronts.
  • BeRad
    BeRad Posts: 745
    edited January 2008
    My thoughts Updated:
    I think that when all is said and done I will end up with an RTI setup run directly off the AVR.
    -Probably still the psw 505 for $300. (100 if i order some other speakers before Tuesday) Worth doing this?
    -I think the CSi3 will be good enough for me but I keep reading that the CSi5 is worth spending another $140 on. Is this true?
    -RTi 4's for rears ($200)
    -FXi A4's for surrounds ($400)
    Down the road upgrade the fronts to RTi10's or something similar. Fronts are staying as R50's for now :)
  • Gizmo99
    Gizmo99 Posts: 169
    edited January 2008
    FXi A4's for surrounds ($250)<- may I ask where you got this?
    Receiver: Onkyo TX-SR805
    Amp: Emotiva XPA-5
    Front: LSI15
    Center: LSIC
    Sourround: FxiA4
    Rear: Fxi3
    Sub: Bic H100
    TV: Sony 52' XBR4
    "The more time you spend researching here, the less money you will have" :D
  • BeRad
    BeRad Posts: 745
    edited January 2008
  • Gizmo99
    Gizmo99 Posts: 169
    edited January 2008
    Please do share once you receive your speaker :)
    Amp: Emotiva XPA-5
    Front: LSI15
    Center: LSIC
    Sourround: FxiA4
    Rear: Fxi3
    Sub: Bic H100
    TV: Sony 52' XBR4
