Harmony 880
solidus28
solidus28 Posts: 83
edited January 2008 in Electronics
Any Harmony owners out there? I'm thinking of purchasing one at some point down the line, but had a question. Let's say I have an activity button set to Watch TV. When I press it, my TV turns on, my cable box turns on, and my receiver turns on. Everything great so far. What if I then want to watch a DVD, so I click the activity button I setup for Watch DVD. Is it going to send the power button signal again, turning my TV, receiver and cable box off, but turning my DVD player on? Or does it know that I never turned everything off and automatically just turn off the cable box, change the input selection on the receiver instead of turning it off, and powering on the DVD player? Hope this isn't too confusing. Thanks for any help!
Post edited by solidus28 on
  • PolkThug
    PolkThug Posts: 7,532
    edited December 2007
  • solidus28
    solidus28 Posts: 83
    Think I found my answer. Should have looked harder in the first place!
    http://www.polkaudio.com/forums/showthread.php?t=46362&highlight=harmony
  • Early B.
    Early B. Posts: 7,900
    Just buy it. I own one. Works great.
    "God grooves with tubes."
  • aba4430
    aba4430 Posts: 80
    edited January 2008
    I have owned one for @10 months now. It is very convenient and we like it. Ergonomically, it stinks (at least for us). However, more pluses to it. I got mine from Dell; most of the time, you can save >$50 buying it on-line vs. local.
  • solidus28
    solidus28 Posts: 83
    edited January 2008
    Best Buy has them for $150 right now. That seems like a good price.
  • Systems
    Systems Posts: 14,873
    edited January 2008
    Santa gave me a 659 and I really like it.Currently I have 2 activities set up.When I press watch TV it turns on the satelite reciever,pre/pro and the TV to the correct input.If I press watch movie while watching satelite it changes the input on the TV and pre/pro turns on the DVD player and turns off the sat dish.
    Testing
    Testing
    Testing
  • pearsall001
    pearsall001 Posts: 5,225
    edited January 2008
    Just out of curiousity, didn't a universal remote come with your avr? My NAD T773 comes with a superb universal. It controls 8 devices, has macro settings that with a push of a button turns on the entire system or how ever you program it.
    I've looked at the Harmony remotes but it seems like an expensive lateral move for me. But if you don't already have a good universal remote, the Harmony remotes sure look great.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited January 2008
    Buy one. My setup is complex as hell - a 720p projector and 43" RPTV, both running off a component matrix switcher so I can use the RPTV for regular viewing and the projector for games/movies. Snagged an 880 for $150 and with a minimal amount of tweaking, it handles every device perfectly.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • zingo
    zingo Posts: 11,258
    edited January 2008
    I always liked this remote, and have been tempted to buy it many times, but my Marantz came will a touch screen LCD remote that is computer programmable, so I can't justify it.
  • solidus28
    solidus28 Posts: 83
    edited January 2008
    I've got a Sony STR-DG1000, but I'm not really too fond of its remote. I use it for setting up/tweaking settings on the receiver, but that's about it.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited January 2008
    I have an 880, love it. Buy one.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2008
    I've had the 880 a year. It generally does the job, but for some reason it doesn't always switch my TV from HDMI to DVD cleanly during operation. I'll have to use the Help function and go through the questions until it correctly sets everything up. I'm pretty sure it's not interfacing with my Mits DLP as advertised. This is no big deal for me, a bummer for the wife. I'll have to update mine today to add the BD player I just picked up.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
