REga P1 TT......
  • dkg999
    dkg999 Posts: 5,647
    edited December 2007
    I've got my eye on the P3 :( Trying hard to resist, must not be assimilated, shields are up and holding :o
    DKG999
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2008
    your shields will eventually give way, resistance is futil, give way to the vinyl force.....
    RT1
  • TroyD
    TroyD Posts: 13,124
    edited January 2008
    All your base belongs to us.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2008
    Since I hijacked Mr Beardog's thread, I'm letting him get into vinyl first ;) If it works for him I'll have to consider it :eek:
    DKG999
  • beardog03
    beardog03 Posts: 5,550
    edited January 2008
    I`m soo confused...!!!
    I started looking at $1600 tables again !!
    I`m thinking the P2
    maybe the mmf 5.1
    or maybe the mmf 2.2
    or maybe thr VPI scout
    maybe the P3
    P1,2,3,4,5,6,7,8,9
    MMF2,5,7,9
    oookayyy!!
    I think I will reread the whole thread again...
    Thanks for all your responses...you know me, and my habits of upgrading, so I will maybe start low-med this time around just to see if it`s for me or not...
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • beardog03
    edited January 2008
    dkg999 wrote: »
    No worries...
    Hijack away...(actually your not) it`s a forum where your responses help me too
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • dkg999
    dkg999 Posts: 5,647
    edited January 2008
    My decision is whether or not to get back into vinyl? After that the only decision is what cartridge to get with the Rega P3. Hopefully something else will come up to occupy my time so I don't continue to consider this move :rolleyes:
    DKG999
  • beardog03
    edited January 2008
    I also want to know what is better / prefered...
    MM or MC cartridges
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
    SCompRacer Posts: 9,090
    edited January 2008
    Don’t forget Avid, Origin Live, Thorens, Nottingham and Sota.
    You have some fine gear bear and I don’t think you will be happy with an entry level table. Just my opinion, but I’d demo some tables before you buy one. Or speak with a knowledgeable dealer or friends based on the sonics you prefer. Table and cartridge combinations can run the range from sporty dynamic, to musical, to rich and warm. If you have a listening taste, a table/cartridge choice is easier. I am fortunate to have some audio dealers nearby that have many brands of tables to choose from and that is how I made my choice.
    In regards to MM or MC, you will get a wide range of opinions. Some are based on old information, as there have been major improvements in MC cartridges over the years. To me, the magic is in low output MC cartridges (<.5mV), provided your table/arm is very good and your phono stage has enough gain (like 65 to 68dB). Ask Joe, I think he would agree. Prior to having a high gain phono stage, I was happy with Dynavector and Sumiko high output MC's. Your likes may be different. A table choice should be like any other piece of audio gear. You either follow or lead. Your choice.
  • madmax
    madmax Posts: 12,434
    edited January 2008
    Its easy to talk yourself up in price bear. I would buy this model (5.1SE) if for some reason I had to start over on a budget. I heard it at bluemdpickers and truthfully would be very happy with it long term. For $300 less I might even try the one right below it, the 5.1 for $699 but have not heard that one. My guess is it would be very similar sounding.
    http://www.musicdirect.com/product/73929
    madmax
    Vinyl, the final frontier...
  • dkg999
    dkg999 Posts: 5,647
    edited January 2008
    I try to stay away from that MusicDirect place :eek: They are way too close to several clients I go see in the city and it gets real expensive to stop by their little retail outlet!
    DKG999
  • madmax
    edited January 2008
    dkg999 wrote: »
    Ha ha, I'm glad I don't ever get to look around there. When I think of all the goodies I could walk out with... :D
    madmax
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2008
    Robert, this is the place to go if you are looking for a Music Hall TT.
    Quest for Sound, Steve Monte is a great guy and is very, very reasonable. . . he'll definitely kill Music Direct's price or anyones price for that matter.
  • beardog03
    edited January 2008
    THanks for all the help guy`s...
    I do appreciate it.
    I have had to deal with some very stressful personl business lately , and haven`t had time to follow up on these leads....but I will..
    and your right...I do want a table that I don`t want to upgrade for quite some time....I must keep the cost down to make sure it`s for me before I get to crazy with it
    I will be using the Cary Pre, so I believe the only cart I can use is MM.....not sure if that narrows the playing field or not
    The one thing I don`t want is what Wingnut said...scratches and pops and no demension, so...
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • madmax
    edited January 2008
    beardog03 wrote: »
    Just pull a few more leaves off the money tree. :D
    madmax
  • TroyD
    TroyD Posts: 13,124
    edited January 2008
    BD,
    Ran accross this, bro. Step up from entry level...good sounding table with limitless potential for modifications...priced right too.
    http://buy.audiogon.com/cgia/cls.pl?anlgtabl&1204409295
    BDT
  • hearingimpared
    edited January 2008
    TroyD wrote: »
    BD,
    BDT
    If you go for this, make sure the seller will be responsible for any shipping occurance. If he had the original packing material I would feel better about the shipping. Ask him how he is going to protect the cartridge/stylus.
  • Face
    Face Posts: 14,340
    edited January 2008
    I couldn't agree more.
    I had a dingbat ship me a TT with the platter still inside! Luckily it didn't really damage anything.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2008
    madmax wrote: »
    madmax
    It looks like the 5.1 models do not have the glass platter like the regular 5 model has.
    I can't buy it now but there is a MMF 5.1 on e-bay in the high $300 (last I checked ) with less that 24 hours to go. I bet it will still go close to the cost of a new one. We shall see.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • madmax
    edited January 2008
    Sounds like there may be a deal waiting for you bear. :D
