Damaged tweeter
kaku42
Someone has depressed the tweeter dome of my center speaker of the RM7200 system.
How do I repair it? Do I need to replace the tweeter or can I pull it out somehow? will it sound the same again?
HELP!!
HELP!!
Post edited by kaku42 on
Try some tape to pull it out first.
Good luck
Ben -
Somebodys been touchin his tweeters.:D
looks like you have discovered one of the signs of tweeter abuse. In some states,it's considered a crime,punishable, with up to 3 years in jail.:eek: Hopefully,it's just cosmetic,,good luck.:)JC approves....he told me so. (F-1 nut)
tried using the tape.. didn't pull it out..
Vaccuum cleaner nozzle. BE GENTLE THOUGH!
Whoa Lightman! :eek: Don't use the vacuum. Use the attachment sucking air with your mouth. If you use the vacuum, you risk detaching the cone altogether.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Hence the BE GENTLE! part.:p
Pay attention, Tom.;) -
Hey, I don't know how well versed he is audio wise. Just wanted to be safe, clarify and not allow him to ruin his tweeter.
Me, pay attention? Ha! In your dreams............~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
