Damaged tweeter
kaku42
kaku42 Posts: 33
edited December 2007 in Troubleshooting
Someone has depressed the tweeter dome of my center speaker of the RM7200 system.
How do I repair it? Do I need to replace the tweeter or can I pull it out somehow? will it sound the same again?
HELP!!
Post edited by kaku42 on
  • ben62670
    ben62670 Posts: 15,969
    Try some tape to pull it out first.
    Good luck
    Ben
    Ben
  • nikolas812
    nikolas812 Posts: 2,915
    Somebodys been touchin his tweeters.:D
  • SKsolutions
    SKsolutions Posts: 1,820
    Tongue marks.
    -Ignorance is strength -
  • george daniel
    george daniel Posts: 12,096
    looks like you have discovered one of the signs of tweeter abuse. In some states,it's considered a crime,punishable, with up to 3 years in jail.:eek: Hopefully,it's just cosmetic,,good luck.:)
  • kaku42
    kaku42 Posts: 33
    tried using the tape.. didn't pull it out..
  • lightman1
    lightman1 Posts: 10,797
    Vaccuum cleaner nozzle. BE GENTLE THOUGH!
    treitz3 Posts: 20,119
    Whoa Lightman! :eek: Don't use the vacuum. Use the attachment sucking air with your mouth. If you use the vacuum, you risk detaching the cone altogether.
  • lightman1
    treitz3 wrote: »
    Hence the BE GENTLE! part.:p
    Pay attention, Tom.;)
    Hey, I don't know how well versed he is audio wise. Just wanted to be safe, clarify and not allow him to ruin his tweeter.
    Me, pay attention? Ha! In your dreams............
