Signal BFA plugs
mhartman29
mhartman29 Posts: 257
Does anyone have any experience with these? I just received my signal cables and they don't seem to want to go all the way into my RT3000s binding post. I'm hesitant to really push hard, as I don't want to damage the plug or the speaker.
They should fit, right?
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Post edited by mhartman29 on
  • solidus28
    solidus28 Posts: 83
    edited December 2007
    I had the same issue with my RTi10s and CSi5. I assumed that's just the way it was because I had never used banana plugs before. Is this about how far yours go?
  • mhartman29
    Yup, that looks about right. What's the deal?
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
  • solidus28
    solidus28 Posts: 83
    Have you used other banana plugs? Do they usually go all the way in? Anyone have any input because now my curiosity is piqued.
  • mhartman29
    No, this is the first time I've used banana plugs with these speakers.
    I assume you aren't having any problems with your connection even though the plug doesn't fully go into the binding post?
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
  • acsubie
    acsubie Posts: 773
    my signal nanners look like that also, i thought i was weird also since the other nanners i have fit in all the way, i havent noticed any sound loss in quality though
  • tcrossma
    tcrossma Posts: 1,301
    I just did a little googling and found this, which may or may not have any bearing on this particular cable's banana plugs and may or may not apply to these speakers. I'm not an expert on banana plugs, but this was interesting...
    BFA terminations are relative newcomers to the field. The British Federation of Audio (BFA) developed the design because of new European safety standards, which ban the use of the 4mm banana plug because it can be inserted into a European AC socket -- with potentially deadly consequences. The BFA connector employs an insulated recessed female plug and an insulated recessed male socket.
    and this
    BFAs are used primarily on components that come from the UK and Europe. Since BFAs are designed to be incompatible with other common terminations, your speaker wires will need a BFA termination if your amplifier has BFA connectors. Some audiophiles report that rolled banana plugs can be made to fit into their sockets, but we at GoodSound! urge you never to force any connection carrying an electric signal. We'd like to keep all of our readers!
    I don't know if what they're saying is that you need to have binding posts specifically made for BFA connectors or not? Do Polk speakers have BFA compatible binding posts?
    I, for one, am now confused :confused:
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • solidus28
    solidus28 Posts: 83
    Everything is working fine for me even though they don't go all the way in. I have those wires going to 2 RTi10s and a CSi5 from an Outlaw M200 and they sound great, so I don't see it as being a problem. I just assumed that's how all bananas were since I hadn't used them and everything seemed to work ok. I would be curious if someone knows the official answer as far as if Polks are BFA compatible. I guess they are since mine work, but then I wonder if an actual BFA compatible post would allow the banana connector to be inserted completely. It definitely works fine, though.
  • mhartman29
    I just spoke with Frank at Signal and he indicated this is not a problem. Depending upon the length of the binding post, the plug may not go in all the way. He said it probably should be about 3/4 of the way in, and fit securely, but it shouldn't have any negative consequences on the sound.
    I second solidus28's curiousity about an official answer to whether Polks are BFA compatible.
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
  • dorokusai
    dorokusai Posts: 25,625
    They are BFA compatible and the connectors sometimes vary in how they fight....it's normal.
