Another dumass HD DVD ?
NeilGabriel
Do you benefit in VQ with HD/BR DVD if your HD TV maxes at 1080i?
Post edited by NeilGabriel on
Yes, SD DVD is only 480p ,or i I don't remember which, HD DVD and BD is 1080p, so you will be getting the maximum resolution your TV can handle and not an unconverted 1080i picture from a 480p source.Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
yes sir you would, I have a 60 screen in the bedroom that maxes out @1080i connected to the Wal- Mart special A2 and the PQ is unreal, its only a 2 chan setup using a pair of Rti4s but sound is excellent as well. Bottom line yes you will benefit and so will your standard def DVDs.Shoot the jumper.....................BALLIN.............!!!!!
Thanks...my wallet is cringing
don't buy into the 1080p shenanigans.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
What do you mean by that exactly, if your saying there is no noticeable difference between 1080p and 1080i, I would say your right.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Depends on how big your TV is, and how far away you're sitting.
There's charts out there that tell you when 1080p becomes noticable or even necessary.If you will it, dude, it is no dream.
