Speaker pop
mikeflores
mikeflores Posts: 19
edited December 2007 in Troubleshooting
I am experiencing speaker pop during source change with a Onkyo 805 and Adcom amp, any ideas on what could cause this? Thanks
Post edited by mikeflores on
  • Jed Leland
    Jed Leland Posts: 182
    Hello,
    It is possible one of your A/V components has a small amount of DC Voltage present at it's outputs. When you make a source selection this DC charge is discharged and you hear a pop. Try removing all of the components you have connected to the receiver, turn the selector a few times to fully discharge any built up Voltage. Then re-connect each component, checking for popping before adding the next. My guess is that there will be one component that causes the sound.
    Cheers, Jed
