Outlaw 7700 & RTi Series
solidus28
solidus28 Posts: 83
edited December 2007 in Electronics
How do you guys think this would match up? 2 RTi12s and a CSi5 for the front. 4 RTi10s for surrounds. Would an Outlaw 7700 be able to make everything 'sing'? Would I be underpowering the speakers, specifically the mains, or would this be a good match? Also, would it be ok to run this setup on the same circuit as my other devices (57" RPTV, PS3, Receiver/Preamp, etc.). I currently have 4 RTi10s and a CSi5 with the front 3 speakers running off of 3 Outlaw M200s. Anyone have experience with this equipment?
  • Grimster74
    Grimster74 Posts: 2,577
    ABSOLUTELY AMAZING, as far as being worried about under powering them, don't think that will happen, they are gonna sing. I've been running the 7700 on my RTi's for quite some time now and it's an excellent combo. As far as running it on the same circuit as the rest of the gear, the 7700 draws some amps when peak notes are hit. I'm running mine on a dedicated 20 amp and the rest of my gear is on it's own 20 amp receptacle. Check out my signature to see my H/T room, roughly running the same speakers as you are other than my mains. If you have any other questions, please feel free to ask.
  • solidus28
    solidus28 Posts: 83
    Awesome setup! Glad to hear this will be a good setup when it finally happens. I'm stuck with apartment living at the moment, so it's a little limiting on what I can do. I don't have the room for the setup I'm asking about at the moment because my couch has to sit up against the wall due to my living room size. If I did have the room in my next apartment, should I still wait to go this route since I'll be stuck with 1 15A for everything?
  • Sherardp
    Sherardp Posts: 8,038
    Save yourself some cash and go with FXi3s and Rti4 or Rti6 for surrounds. Other than that, the 7700 would and will do the trick just fine.
  • solidus28
    solidus28 Posts: 83
    I've already got 4 RTi10s since I took advantage of Sound Advice's BOGO offer a few weeks back. I was thinking of getting RTi12s to replace the current mains (RTi10), then I'd just move the 10s to surround duty. It will be a while before any of this happens, though. I may go ahead and get the amp, but the additional 2 speakers will have to wait until I move at some point.
  • Sherardp
    Excellent deal bro.you'll be fine.
