Specs for RTA-12b's
jgalvez9780
jgalvez9780 Posts: 3
edited December 2007 in Vintage Speakers
Does anyone have the owners manuel or specs for the RTA-12b's? I just picked up a pair but the previous owner could not locate it at the time. Also does polk carry suitable replacement woofers for these? Any info would be appreciated. Thank you.
Post edited by jgalvez9780 on
  • Face
    Face Posts: 14,340
    Call Polk on Monday morning, they still sell replacement woofers.
    As for specs, you should be able to find them by using the search feature here.
  • tx_polkhead
    tx_polkhead Posts: 248
    The woofer is just a passive radiator, why are you replacing it? Did it get damaged? I am new to the Polk world as I have only had my rta-12c's for a few months but smile every chance I get to push them. Please take pictures of the insides of the speakers if you wind up replacing the 'woofers'.
    Abel
    here is a pic of my naked rta-12c's
    photo#5132686376358547394
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
  • tx_polkhead
    well let's try that again
  • tx_polkhead
    that's right I'm not sure what I'm doing wrong!
    if all else fails here is a link:
    http://picasaweb.google.com/aas.sanchez/PolkAudioRTA12C
  • dorokusai
    dorokusai Posts: 25,633
    Yes, you may still purchase replacement mid-bass drivers.
  • jgalvez9780
    I was just wondering if they had replacements. The ones I purchased are in excellent condition except for the grill post that hold the top hat grill. 3 are broken but I am going to replace them.
  • dorokusai
    You can also get them direct from Polk.
  • jgalvez9780
    Hey I am also not getting the bass response I thought these might give out. Any insight?
  • Boywonder
    Boywonder Posts: 225
    You can get the grill posts (headlock fasteners) from any speaker supply place like Madisound or Parts Express. The generic kind fit the top of the cabinet perfectly (I just replaced 3 of mine today) The tops of my "top hat" grilles were a bit faded, so I bought some black fabric dye (RIT, in a bottle) and used a pump sprayer to re-blacken the tops of the top hats. They look like new after the spritzer.
  • tx_polkhead
    Boywonder, do the headlock fasteners unscrew or just pull out? I need to replace three, and have yet to do it, figured gravity would keep the top hats in place. After a loud listening session I noticed both top hats had vibrated so the sat askew, yep they play loud!
  • dorokusai
    Boywonder wrote: »
    The PE ones don't fit perfectly. They fit, but the actual treelock is a bit smaller.
    TX - Sometimes they pop out easily, sometimes not. Be careful as getting them out may damage the veneer around it. I usually drill out the center and them get the rest out with small pliers and a dental pick.
  • tx_polkhead
    thanks for the info, now where did I put my dental pick set (only funny because like you I also have one!)
  • dorokusai
    :D I've found it to be a handy tool for many things.
  • Boywonder
    I drilled them out and pried them off with a small pointy tool. My headlocks have been in the drawer from a speaker project exactly 20 years ago, so I actually haven't bought any recently from PE or Madisound.....
    Are both of your mid-woofers 6501's with original dates?? Mine RTA-12's also have differing dust caps, but I was assuming it was because the outer drivers were replaced with 6503's. I guess my question is are the drivers in a original pair of RTA-12C's the same?
  • Face
    Face Posts: 14,340
    New fasteners are available through Polk too.
