Speaker Additions
tonyk1
I have an older set of polk rt-800 floor standing speakers. If I use these as the l-r front channels on a 5.1 surround, will the polk rm 6750 be a good match for the remaining speakers?
Post edited by tonyk1 on
for surrounds it mightbe ok, but I think those little Rm's might be a little light for center duty. dont get me wrong, it will work and sound ok, but you "to do" list audiowise will have upgrading the center right at the top.
look for a cs400, or a cs350 on the used market on ebay. usually can be had for less than 250 or so, and will make a HUGE difference.
biggr surrounds will be nice, but nowhere near as important as gettin ghtat center up to snuff for your mains.
either way, your on the path, have fun
Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Thanks for the info oshkigod, Its nice to know some things before breaking out the wallet !!
nothing wrong with researching a decision at all. it's part of the audio journey. have funLiving Room 2 Channel -
Is there anything new that is comparable to the cs400 or cs350? I just don't like going the used route on some things.
Sometimes the light at the end of the tunnel is an oncoming train. -
the CSi5 will be the closest timre match you'll find new. the CSi5 is a great center, just not an exact match to what you have. will still be much better than the little center you got nowLiving Room 2 Channel -
Oh, so now i"m impotent huh? LOL........ how much does it affect the center channel when its behind the tv monitor?
hey, sometimes ya get quick service.........sometimes
by behind the monitor, do you mean actually behind the TV? the center should be on top or below, and not have anything in the way between the speaker and the listening position/area. possible exception is a projector screen specially designed to be sound transparent, but there pricey.Living Room 2 Channel -
The CSi5 should be a pretty close match and vastly superior to an RM center. I think you can get away with using the RM's for surrounds for HT, but I would not use them for music that much. I have a similar situation....very strong front stage and somewhat limited surrounds due to spacing and wiring issues. I use the Monitor Audio cubes with back firing tweeters soley for movies, and they work well for that. All of my music is played in stereo, and the set up works out fine. Should for you too....but, definitely upgrade that center. And, like ohskigod says, unless you have some kind of transparent screen, you want that center right above or below the monitor......as close to ear level as you can make it.B&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Monitor Radius 180 surrounds
Audiosource Stereo Amp for surrounds
Denon 2910 Universal DVD/SACD Player
Comcast DVR
Pioneer Elite 42" Plasma 940 HD
Harmony Universal Remote
Blue Jeans interconnects and biwires
Itunes Air Express
