Speaker Additions
tonyk1
tonyk1 Posts: 15
I have an older set of polk rt-800 floor standing speakers. If I use these as the l-r front channels on a 5.1 surround, will the polk rm 6750 be a good match for the remaining speakers?
Post edited by tonyk1 on
  • ohskigod
    ohskigod Posts: 6,505
    edited December 2007
    for surrounds it mightbe ok, but I think those little Rm's might be a little light for center duty. dont get me wrong, it will work and sound ok, but you "to do" list audiowise will have upgrading the center right at the top.
    look for a cs400, or a cs350 on the used market on ebay. usually can be had for less than 250 or so, and will make a HUGE difference.
    biggr surrounds will be nice, but nowhere near as important as gettin ghtat center up to snuff for your mains.
    either way, your on the path, have fun :D
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • tonyk1
    tonyk1 Posts: 15
    Thanks for the info oshkigod, Its nice to know some things before breaking out the wallet !!
  • ohskigod
    nothing wrong with researching a decision at all. it's part of the audio journey. have fun
  • tonyk1
    tonyk1 Posts: 15
    Is there anything new that is comparable to the cs400 or cs350? I just don't like going the used route on some things.
  • tonyk1
    tonyk1 Posts: 15
    tonyk1 wrote: »
    Sometimes the light at the end of the tunnel is an oncoming train.
  • ohskigod
    the CSi5 will be the closest timre match you'll find new. the CSi5 is a great center, just not an exact match to what you have. will still be much better than the little center you got now
  • tonyk1
    tonyk1 Posts: 15
    Oh, so now i"m impotent huh? LOL........ how much does it affect the center channel when its behind the tv monitor?
  • ohskigod
    hey, sometimes ya get quick service.........sometimes :D
    by behind the monitor, do you mean actually behind the TV? the center should be on top or below, and not have anything in the way between the speaker and the listening position/area. possible exception is a projector screen specially designed to be sound transparent, but there pricey.
  • john22614
    john22614 Posts: 214
    The CSi5 should be a pretty close match and vastly superior to an RM center. I think you can get away with using the RM's for surrounds for HT, but I would not use them for music that much. I have a similar situation....very strong front stage and somewhat limited surrounds due to spacing and wiring issues. I use the Monitor Audio cubes with back firing tweeters soley for movies, and they work well for that. All of my music is played in stereo, and the set up works out fine. Should for you too....but, definitely upgrade that center. And, like ohskigod says, unless you have some kind of transparent screen, you want that center right above or below the monitor......as close to ear level as you can make it.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
