Expert Advice needed: -3dB limits
Mr. Mojo
What does -3dB really mean?
It seems to be related to the upper and lower frequency range.
How often does this come into play for listening to movies/music?
Thanks for any help or expertise.
Post edited by Mr. Mojo on
I believe its a response bandwidth measurement and meaningless to a consumer at large. You will never hear a +/- 3db difference unless you are a Vampire or actual bat type creature.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Just tells you the frequency at which speakers start rollling off highs and lows._________________________________________________
It means at a given frequency, the speaker is 3 decibels quieter than it is at a reference level. 3db is very noticeable with test tones. With actual music you may/may not notice. -
It's used to show the decrease in level at that frequency to demonstarte how flat the frequency response curve is across a range.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
yea, what they said and when a speaker hits its lower -3b point the SPL never goes back up as the frequency continues to drop so its known as the roll-off point. The spec is something to consider when you buy the speakers but after they are home you might want to set your crossover as already suggested.
RT1
