Expert Advice needed: -3dB limits
Mr. Mojo
Mr. Mojo Posts: 53
What does -3dB really mean?
It seems to be related to the upper and lower frequency range.
How often does this come into play for listening to movies/music?
Thanks for any help or expertise.
Post edited by Mr. Mojo on
  • dorokusai
    dorokusai Posts: 25,576
    edited December 2007
    I believe its a response bandwidth measurement and meaningless to a consumer at large. You will never hear a +/- 3db difference unless you are a Vampire or actual bat type creature.
  • Ricardo
    Ricardo Posts: 10,634
    Just tells you the frequency at which speakers start rollling off highs and lows.
    SOPA
  • PolkThug
    PolkThug Posts: 7,532
    Mr. Mojo wrote: »
    It means at a given frequency, the speaker is 3 decibels quieter than it is at a reference level. 3db is very noticeable with test tones. With actual music you may/may not notice.
  • steveinaz
    steveinaz Posts: 19,546
    It's used to show the decrease in level at that frequency to demonstarte how flat the frequency response curve is across a range.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    yea, what they said and when a speaker hits its lower -3b point the SPL never goes back up as the frequency continues to drop so its known as the roll-off point. The spec is something to consider when you buy the speakers but after they are home you might want to set your crossover as already suggested.
    RT1
