Need help with RT1000i/Onkyo 605
newsonic
newsonic Posts: 2
I need advice on hooking up the powered subwoofers on the RT1000i tower speakers to an Onkyo 605 receiver. The receiver has only one input for a subwoofer.
What is the preferred method of hooking the two subwoofers to the receiver?
Thanks for your help.
Post edited by newsonic on
  • obieone
    obieone Posts: 5,077
    edited December 2007
    I'm no guru, but I'm assuming you don't have the owners manual-no sweat.
    I'm attaching the file, it's PDF. It's got three different options for wiring, based on whatever set up you've got.
    Welcome to the forum, good luck, and check back in if you need further assistance:cool:
  • newsonic
    newsonic Posts: 2
    Many thanks for taking the time to post the manual. That really helps.
  • ohskigod
    ohskigod Posts: 6,505
    gotta try different things with power towers. I never owned power towers, so I cant help much. do you have a regular sub as well, or are you just using the subs in the towers for all your bottom end duty?
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
