New system...may have made a mistake!
sdcfan19
sdcfan19 Posts: 56
edited December 2007 in Speakers
I'm just started a new job in the last 3 months and have really been upgrading the HT. I've bought quite a bit of stuff but think I might have made a mistake. This is the system I have
LSiC center
RTi10 fronts
M20 rears
Pioneer VSX-1017 AVR
The fronts and rears are rated for 8ohms, but as you well know, the center is rated for 4ohms. I've been running this for about 3 weeks and everything is running fine (only mild garbage but I only get this with satellite, not DVD or XBOX 360). Are there any problems running the center with this amp? I might look at selling it and going to a CSi A6. I've also read that a preamp might be the item I should look for. If thats the case, I only have about $400, so is there a brand and model that would work best? Any info would help guys. Thanks in advance.
Samsung Plasma (50A530)
Bell ExpressVu 6100
Toshiba PRV (RD-SX35SU)
Pioneer DVD w/upconvert (DV-490V)
PlayStation 3
Harman Kardon AVR 354
Polk CSi A6 Center
Polk RTi10 Fronts
Polk M20 Rears
D-Box Sub
Harmony 880
Acoustic Research/Rocketfish cabling
Post edited by sdcfan19 on
  • dorokusai
    dorokusai Posts: 25,576
    It's not rated for it but I wouldn't expect any issues with a single 4ohm loudspeaker.
    Get the right center channel. The CSiA6 is a great choice for the RTi10. Don't worry about a pre-amp at this point.
  • tcrossma
    tcrossma Posts: 1,301
    A pre-amp isn't going to do you any good unless you have a separate power amp. I don't think the LSiC is timbre matched with those speakers, but it *is* a damn good speaker (I have one). The LSI series likes power, so you'd probably get more "oomph" from that center if you had more power than the AVR will give you, but what you have will work.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • beardog03
    beardog03 Posts: 5,550
    dorokusai wrote: »
    good advise, IMO...
    and welcome to Club Polk !
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Sherardp
    Sherardp Posts: 8,038
    or try to find a CSi5 on sale.
  • Yashu
    Yashu Posts: 772
    Yeah... the center you have is not voice matched to the mains. You definitely need to keep all the speakers from the same basic series. The better budget route for the rears would be monitor 30s, that uses the same exact tweeter as RTi, but the center is more important at this stage and it is way off as far as sound goes when compared to the mains. CSi5 is the way to go if you can find one... or whatever they replaced it with. Just anything that uses the polk silk tweeter from the RTi. That LSi vifa is worlds apart from the RTi tweeter and you are not getting a seemless soundstage.
  • sdcfan19
    sdcfan19 Posts: 56
    Yashu wrote: »
    Does the CSi A6 have the silk tweeter?
    Bell ExpressVu 6100
    PlayStation 3
    Polk CSi A6 Center
    Polk RTi10 Fronts
    Polk M20 Rears
    D-Box Sub
    Harmony 880
  • jflail2
    jflail2 Posts: 2,868
    I currently have RTi-10's and a CSI-3 and am running them with a simple Denon receiver. It has preamp outs for when I add an amp down the road, but the system sounds surprisingly good to not have more power. I'm sure the 100w per channel is not enough to coax out the sound these speakers are capable of, but I can't complain with this setup considering I wasn't financially prepared to pick up an amp as well at the time.
    That being said, I am seriously considering selling my reciever to a friend and picking up an Emotiva pre/pro combo....
  • nm4710
    nm4710 Posts: 97
    I'm running an RTi10/CSi5/RTi6 setup. I've tried a few different receivers (HK 245, Sony 5300ES, Denon 2808) and I've tried a few different outboard amps as well. Here's my take: only a very high end receiver (top of the line Denons, Adcom, Rotel, etc.) is going to drive the CSi5 and RTi10 to anywhere near potential. Frankly if you're not going to invest in one of those top line receivers or outboard amps there is no point in even buying these speakers. For the budget-minded an RTi4/CSi3 setup with a good sub will take you much further.
    Keep in mind that this advice is coming from someone who made exactly that mistake. I've even tried my RTi10s with the denon 2808...in my honest opinion they fell flat. The woofers on the 10's barely moved and the bass output was unimpressive.
    Also the CSi5 is a real power hog...it sounds ok with modest power...but truthfully hardly any better than a CSi3. When you throw 200 watts its way it is noticeably better than the CSi3...but the difference isn't nearly as dramatic as you'd be led to believe.
  • Early B.
    Early B. Posts: 7,900
    Your speakers are fine. Take that $400, buy a subwoofer, and enjoy.
    "God grooves with tubes."
  • sdcfan19
    sdcfan19 Posts: 56
    I should have mentioned that I have a sub. It's not top end, but its something that I might replace in the new year. I bought the CSi A6 tonight and WOW, what a difference. I really wasn't getting close to this much out of the LSiC. The next issue is the fronts (RTi10's). They are great for movies and TV, but when it comes to music they fall a little short. I had the AVR turned up to -10dB and it wasn't loud at all (for my taste).
    Like I said in my first post, I'm kinda new at this and am learning quickly. Would an amp help my situation? I've started looking into some and like what I've read. When it comes to amps, I'm REALLY new. I know basically nothing when it comes to them. Are they going to give me louder fronts? What are some good names? What is the price range? What make/model will work well with the RTi10's?
    Bell ExpressVu 6100
    PlayStation 3
    Polk CSi A6 Center
    Polk RTi10 Fronts
    Polk M20 Rears
    D-Box Sub
    Harmony 880
  • Yashu
    Yashu Posts: 772
    I would look into some good amplification like Adcom. They make stong amps that are pretty good priced.
    There are other brands... like outlaw, and some others that people here like... (I like NAD, but they don't make but one amp now, they used to have a selection, but they only have the one c272, which is probably overkill) but Adcom is right up your alley. That will get those RTi10s singing. Also look into new rears to complete the set... maybe some monitor 30s or RTI4s. Then you will have matching tweeters all around and it will sound pretty damn good.
  • sdcfan19
    sdcfan19 Posts: 56
    I'll look into that. Thanks for the advice.
    Bell ExpressVu 6100
    PlayStation 3
    Polk CSi A6 Center
    Polk RTi10 Fronts
    Polk M20 Rears
    D-Box Sub
    Harmony 880
  • sdcfan19
    sdcfan19 Posts: 56
    Kex wrote: »
    That answered the majority of my questions. I've spent a lot of time looking for something just like that. A big thanks goes out to everyone that has helped me. Your input and patients has gone a long way in helping me with the HT.
    Bell ExpressVu 6100
    PlayStation 3
    Polk CSi A6 Center
    Polk RTi10 Fronts
    Polk M20 Rears
    D-Box Sub
    Harmony 880
  • cfrizz
    cfrizz Posts: 13,415
    That's why we are here! Welcome to Club Polk, enjoy your new system.
