Best Turntable Record Cartridge for SDA-2?
jsiatczy
I just discovered this forum yesterday. I am a long time Polk Audio supporter, having bought a pair of Monitor 7's in 1980. I am the proud owner of Polk Monitor 4, SDA-2 (the originals), Polk CS1, PSW 10 and 4 Monitor 30's for the surround and 4 Polks in the auto, of course. I sold the Monitor 7s to my younger brother who still swears by them today. I would too, if I still owned them
Having also just discovered records again, what is the best Cartridge for my system in the $100 - $300 range?
Receiver: Yamaha RX-V661 (2007)
Turntable: AR Turntable (1987 model)
Current Cartridge: AT 155LC (1989?)
Thank you!
Thank you!
Post edited by jsiatczy on
Can your Yamaha handle the low voltage of moving coil cartridges.
Imagine that, I would have never thought this mid line receiver would be capable of using MC cartridges...it is unadvertised anywhere on their web site/literature for this particular receiver. Having never had the opportunity to use a MC cartridge, is the lower volume output normal? What would you use to bring the lower volume up, a Phono Pre-amp? What is a good one if to consider that is the case?
Having said that, I never realized how good a cartridge I currently have (AT155LC) based on some research on this forum and other sites. What does a MC bring to the table that a MM doesn't. What are good MC cartridges to consider?
Thanks!
Thank you for your inquiry regarding Yamaha product. The RX-V661 can handle a moving coil cartridge. However you may experience lower volume output from the phono player. Thank you again for your inquiry and have a wonderful holiday.
Best Regards,
The Yamaha Customer Support Team
Receivers [AV and Stereo]
Model: RX-V661
Can the RX-V661 handle a Moving Coil Record Cartridge on the Phono inputs? -
Here is a link to a very high level explaination of the difference between the two.
A good moving coil cartridge that you can start out with is the Dynavector 10 x 5. You see them typically priced at $380 but you can do much better if you shop around the net.
The 10 x 5 is a higher output MC cart and you won't find yourself turning the volume control up too high to get a decent volume. -
Thanks for steering me in the right direction!
