noise from the front speakers
sudhakar.sv
sudhakar.sv Posts: 2
Hi All
Please help
In my car i have polk audio rear speakers and front speakers i have put boston components. recently i connected audison 5 channel amp. I have not connected sub woofer yet.
When I start my engine i get this sparking noise from my front speakers.
I tried connecting noise filters but it didn't help :confused:
When i switch on the AC the noise increases.
When i use the horn then the noise power also increases.
When i remove the antena connection the noise reduces but it does not stop it is still present.
Also i read in one of the posts
"check and make sure your remote wire is not pinched. i had the damndest time figuring out the remote wire will cause noise if the insulation is rubbed thin in a spot"
Can anyone please explain what this means.
Post edited by sudhakar.sv on
  • obieone
    obieone Posts: 5,077
    edited December 2007
    Try reposting this thread in 'car audio'
    Welcome to the forum, and good luck
  • ohskigod
    ohskigod Posts: 6,505
    this is definitly one of those issues I think the car guys will know in like 2 seconds. might very well be the wire your using, but again, I am not the expert. the car forums are below the home audio forums.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
