noise from the front speakers
sudhakar.sv
Hi All
Please help
In my car i have polk audio rear speakers and front speakers i have put boston components. recently i connected audison 5 channel amp. I have not connected sub woofer yet.
When I start my engine i get this sparking noise from my front speakers.
I tried connecting noise filters but it didn't help
When i switch on the AC the noise increases.
When i use the horn then the noise power also increases.
When i remove the antena connection the noise reduces but it does not stop it is still present.
Also i read in one of the posts
"check and make sure your remote wire is not pinched. i had the damndest time figuring out the remote wire will cause noise if the insulation is rubbed thin in a spot"
Can anyone please explain what this means.
Please help
Try reposting this thread in 'car audio'
Welcome to the forum, and good luckI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
this is definitly one of those issues I think the car guys will know in like 2 seconds. might very well be the wire your using, but again, I am not the expert. the car forums are below the home audio forums.Living Room 2 Channel -
Upstairs 2 Channel Rig -
