Should i modify my RTi's?
GSRBOB
I'm so bummed.:( I just found out that the replacement tweet's r $90 a piece on my RTi 10's and CSi5. Now i'm considering buying different tweeters and retrofitting them. Has anyone done this to there's? Oh and thanx in advance for any positive advice.
My first post! Did'nt see an intro section.
Onkyo TX-NR801
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
Pwr- Monster HTS 3600
LCD- KDL-40XBR2
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
LCD- KDL-40XBR2
Post edited by GSRBOB on
Thanx.Onkyo TX-NR801
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
LCD- KDL-40XBR2 -
Why are you needing to replace them?
You need to bite the bullet, and get the correct parts.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
They no longer work. I also thought about buying another set of RTi 6's or 4's because they are close to the same price i would pay for two tweeters, and then just buy the tweet for the CSi5.Onkyo TX-NR801
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
LCD- KDL-40XBR2 -
All three no longer work?! What happened?
This isn't something silly like the jumpers were removed, right? -
I'm embarrased to say i blew them.Onkyo TX-NR801
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
LCD- KDL-40XBR2 -
My ears r still ringing:DOnkyo TX-NR801
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
LCD- KDL-40XBR2 -
Distortion?Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
I would suggest buying the correct drivers as well. If you don't want to absorb the cost, different drivers are not a solution, just a band-aid and they often sound awful.
There's more to loudspeaker design than the speaker in play here, as the crossover was also developed around the factory speaker. It's not just about dropping in something that fits.
Let us know what you do or want to do.....CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Why not use the waranty?
Cant find the reciet.Onkyo TX-NR801
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
LCD- KDL-40XBR2 -
Dare I ask how?
My thoughts exactly, can you tell us what happened. Were you rocking them out that loud? I can only imagine how much noise you were making with them, those things go insanely loud. What AVR are you using on them?Shoot the jumper.....................BALLIN.............!!!!!
Ya i got a little carried away. My AVR is an Onkyo TX-NR801. I wish i would have gotten into an HK but Circuit City didnt have the one i wanted at the time. Now i have a different perspective on things. Id like to go with seperate amplification. The Sunfire products look good just havent really researched yet. Nice setup by the way.Onkyo TX-NR801
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
LCD- KDL-40XBR2 -
You don't need a receipt. The warranty is thru Polk, not Circuit city.Do you still have the boxes the speakers came in? they should've come with a warranty card?I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Hold your horses Obieone, as a receipt and/or proof of purchase is required for warranty coverage from every manufacturer on the planet. When it comes to Circuit City, they often handle warranty claims onsite but that may have changed over the past year. The consumer has the option of handling it with CC or directly with the manufacturer.
GSRBOB - I would suggest you contact Polk Customer Service and see what they are willing to do for you sans receipt. If you sent in your warranty card, you should be just fine.
polkcs@polkaudio.com
9am - 6pm, M-F, EST (USA)
800-377-7655 toll free phone
410-764-5470 faxCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
With their computer, CC should have a record of when you bought them.
Listen to Mark....he wouldn`t steer ya wrong..
any other option you were concidering is just foolish...IMOCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
I looked up the specs on the Onkyo TX-NR801, it shows 100 w/channel.
The Rti8 shows efficiency at 90db.
The Csi5 shows efficiency at 90db.
I can see why your ears were ringing.
You're not going to save that much money by going with "It'll-Fit" replacement tweeters, and you'll kick yourself in the rear if you do.
As others have mentioned, get ahold of Polk; if you have the warranty cards from the box, you should be good to go.
Our 7.1 system is powered with a Lil' Onkyo (503) at 75 w/channel. After 4 months of keeping the reins on the horse, we (okay, I) decided let's see what she'll do.
"Fast and Furious". Our speakers have similar efficiency ratings (lower on the ladder, mind you), but the railroad track scene was played at max volume with the grills off all speakers.
The Polks soaked it all up, and said "Thank you sir, may I have another".
Knocked pictures off the wall, etc, so I can't imagine the sound level in your room to get 3 tweeters to blow.
As others will tell you, fewer tweeters get popped with high power amps than vice versa.
While deciding on the route you're going to go regarding tweeter replacement, you might want to check your speaker wiring hookup (any spare strands, etc).
Good luck !Sal Palooza -
yeah, I'm curious too; how the hell did you blow those tweeters out, and on 3 different speakers? I run an Onkyo TX-SR703, with Rti6s, 4s, and a CSi3. I've cranked the amp full tilt, and never even heard distortion through them. My amp is 100 watts a channel, very very similar to what you were using. Sounds like something may be wrong with your amp or a distortion issue.
That being said, I supervise over at CC, and we keep good records of purchases. Basically, if we took down your name, or you know the credit card you used, we'll have a record of it (I've dug up stuff from purchases 15 years ago). The problem though, is that we haven't carried RTi in close to 5 years, so your speakers might be out of warranty anyhow.
Replace those tweeters with the proper ones. If you try to cheap it out, you'll probably still spend a decent amount on the tweeters, and end up with something that sounds worse than cheapo speakers that cost less than your replacement tweeters.
