Cable for 1.2TL's?
buckfishing
buckfishing Posts: 11
edited December 2007 in Vintage Speakers
Thanks for the response on my first post, I have a lot to learn about these gems! first order of business is to get a interconnect cable for these. What's the best course of action?
How do I order the Compendium book?
Do I keep these OEM or go custom?
Couple of the Tweets sound out of whack, is that common?
And thanks for all the good comments about my lucky find on these last night and today.
Buck
Post edited by buckfishing on
    F1nut Posts: 52,243
    Again, the first order of business is to figure out which model you have. Can you help us with that?
  • shadowofnight
    shadowofnight Posts: 2,735
    A picture would be really helpful...If he is sure these are tl's ( Pin/Blade...Sl3000 tweeters ) then it should be really simple...if he isnt sure ...then we go to the ohm meter and IC/Tweeter config to see what version SRS, 1.2's these are. Shoot a front and rear pic for us por favor
    Even cell phones have cameras now :)
    The first rule of Fight Club is you don't talk about Fight Club
  • shadowofnight
    Ha...I have John Candy pictured when reading this thread... :D
  • buckfishing
    I can't seem to get the pics to show up on this reply, they are on my post from the 13th. They are ok pics, will this be enough for specifying how to do the interconnect cable..
    Buck
  • John in MA
    John in MA Posts: 1,010
    The blade of the blade/pin connector is the second conductor for the AI-1 isolation transformer.
  • hearingimpared
    hearingimpared Posts: 21,136
    John in MA wrote: »
    That is correct. If you check the back plate you will see that the blade is wired to the bottom negative post which is where the SDA array comes off of.
  • buckfishing
    I took video RCA gold heavy gauge for round pin, then took standard RCA and flattend with hammer just so it fits snug into the flat pin space. It seems to work well. Great advice!!!!!!
    Now for the tweeters, it sounds like I have a bad one in the right, sounds like it has static in it. Is that an indication of a blown tweeter(SL 3000). If I go through each one do I test it through something as small as an ipod? or just run off my system at low volume. Thanks again for the finer points on getting these beauties sounding the way they should.
    Buck
