Is 200w too much power for AR speakers?
mgenix171
I am not impressed with a Denon 2106 so I have decided to upgrade. I was looking at either Onkyo 805,875 or 905. But after going thru this forum I have changed my mind & opted for a 5-channel Amp with 200wpc. I have narrowed the amps down to either Outlaw 7500 or Rotel 1095.
I have a pair of Acoustic research 'The Edge' as my surround speakers, in a 5.1 system. These are rated at 150w. If I use the 200wpc 5-channel amp will this damage the speakers? Or should I just connect the fronts & center to the amp & leave the AR's on the Denon? If this is the case then I am tempted to get an Emotiva MMC-1 & an IPS-1 & be done with it, since it is rated at 150wpc. The other speakers consist of RTi12,CSi5,PSW505.
Denon 2106, Outlaw 7500, RTi12(fronts), CSi5, Acoustic Reseach 'The Edge'(surround), PSW505, PSW 404, BJC 10 white, LC-1 & interconnects
Post edited by mgenix171 on
Good clean (ie non-distorted/clipping) power won't hurt speakers. You could use a good 600 wpc amp with your surround speakers and it won't hurt them. The one exception is if you drive the speakers at sound pressure levels they can't handle. You can do that with a 50 wpc amp, or a 150 wpc amp.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
What DKG said! Either one of those amps will do just fine.
Welcome to CP.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
