My wires finally corroded
PolkThug
PolkThug Posts: 7,532
My 26 cents a foot Home Depot 12awg wires are finally showing the green corrosion. I've read that copper oxide is not a good conductor, so, do I spend 5 more bucks or try to get something "better"?
Will all copper speaker wire eventually corrode? Most of the aftermarket choices do not have clear jackets so you can't see what the wire looks like after a few years.
edit: I think my rears have the OFC stuff, so they are fine.
Post edited by PolkThug on
  • ben62670
    ben62670 Posts: 15,969
    edited December 2007
    The whole wire is corroded? Usually you can cut 6"s off each end, and still have the quality you had before. Remember electrons flow on the outsides of the wires. Especially higher frequencies.
    Ben
  • PolkThug
    The whole things aren't corroded, just got the tarnished penny thing going on in spots. (jackets are clear so I can see the whole length of wire)
    F1nut Posts: 52,005
    Some have commented that the clear plastic covering helps promote the corrosion issue. In fact, I've seen cables with the clear plastic covering that the entire lenght of cable had turned green.
    The better cables seem to address the corrosion issue by sealing the ends and using much better teflon outer jackets.
  • Face
    Face Posts: 14,340
    I have a pair of 10 year old Monster Cables that this happened to.
  • ben62670
    Face wrote: »
    I have two pairs of monsters that happened to.
    Ben
  • Sherardp
    Sherardp Posts: 8,038
    I'd go for the 12 awg Belden wire from Blue Jeans and call it a day.
