My wires finally corroded
PolkThug
My 26 cents a foot Home Depot 12awg wires are finally showing the green corrosion. I've read that copper oxide is not a good conductor, so, do I spend 5 more bucks or try to get something "better"?
Will all copper speaker wire eventually corrode? Most of the aftermarket choices do not have clear jackets so you can't see what the wire looks like after a few years.
edit: I think my rears have the OFC stuff, so they are fine.
Post edited by PolkThug on
The whole wire is corroded? Usually you can cut 6"s off each end, and still have the quality you had before. Remember electrons flow on the outsides of the wires. Especially higher frequencies.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
The whole things aren't corroded, just got the tarnished penny thing going on in spots. (jackets are clear so I can see the whole length of wire)
Some have commented that the clear plastic covering helps promote the corrosion issue. In fact, I've seen cables with the clear plastic covering that the entire lenght of cable had turned green.
The better cables seem to address the corrosion issue by sealing the ends and using much better teflon outer jackets.Political Correctness'.........defined
President of Club Polk -
I have a pair of 10 year old Monster Cables that this happened to.Some have commented that the clear plastic covering helps promote the corrosion issue. In fact, I've seen cables with the clear plastic covering that the entire lenght of cable had turned green."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I have two pairs of monsters that happened to.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I'd go for the 12 awg Belden wire from Blue Jeans and call it a day.Shoot the jumper.....................BALLIN.............!!!!!
